69 / 70 Charger tail lights #1415694
04/07/13 01:44 AM
04/07/13 01:44 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Can anyone confirm that the aluminum finish panel is only used on 70 Chargers?
and only 69 have a die cast trim around the plastic lens?
Thanks much..
Re: 69 / 70 Charger tail lights [Re: sthemi] #1415695
04/07/13 02:33 AM
04/07/13 02:33 AM
All 69's had the white metal chrome trim around the tail lights. 70's could have come with the white metal chrome trim on base models or could have come with the full aluminum finish panel on higher models.
Hope this helps.
Re: 69 / 70 Charger tail lights [Re: ] #1415696
04/07/13 02:40 AM
04/07/13 02:40 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 70 Charger 500s and R/Ts had the aluminum taillight finish panel. NO 68 or 69 model came with it.
Re: 69 / 70 Charger tail lights [Re: Kern Dog] #1415697
04/07/13 03:10 AM
04/07/13 03:10 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks for the replies,
Looks like I have some extra 70 taillights for the for b body parts section..
Re: 69 / 70 Charger tail lights [Re: sthemi] #1415698
04/07/13 06:43 PM
04/07/13 06:43 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
The '70 lights also have a rectangular reflector built into the lens also
1MYTGTX
Re: 69 / 70 Charger tail lights [Re: 1MYTGTX] #1415699
04/07/13 09:04 PM
04/07/13 09:04 PM
Mass
charge70 Offline
charge70  Offline
Mass
Only after 1-1-70,before that date they looked just like 69 lenes,no rectangular reflector built in.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 69 / 70 Charger tail lights [Re: charge70] #1415700
04/07/13 11:22 PM
04/07/13 11:22 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thank you !
