D-150 axle interchange #1415616
04/06/13 11:55 PM
04/06/13 11:55 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
I have a 1985 D-150 with an 8 1/4 open axle, big bolt pattern, and a 1981 D-150 parts truck with a 9 1/4 sure-grip, small bolt pattern, I would like to swap the 9 1/4 into the '85, but retain the large bolt pattern, are the 8 1/4 and 9 1/4 axle shafts interchangeable?, if not, what do I need to do to my early 9 1/4 to get the big bolt pattern so I can re-use my aftermarket big bolt pattern wheels to work?
Re: D-150 axle interchange [Re: tt76400] #1415617
04/07/13 12:20 AM
04/07/13 12:20 AM
New Richmond, WI
K
kams Offline
kams  Offline
K
New Richmond, WI
The axles will not interchange. to get the 9 1/4 rear with the 5x5.5 bolt pattern go to the salvage yard and find 4x4 dodge 86-93 with the 9 1/4 and pull the axles out and.
The drums from the 8 1/4 should work as long as they are the same size drum brakes if not chance the whole drum assembly out. drive shaft might not work?
Hope this helps.
Re: D-150 axle interchange [Re: kams] #1415618
04/07/13 01:13 AM
04/07/13 01:13 AM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Drums are the same, so no problem there, 8 1/4 and 9 1/4 are the same dimension for drive-shaft length, so that is not an issue, I just needed to know if the axle shafts would swap or am I looking for different axles or bolt pattern adapters/spacer, which I really didnt want to use, but considering what I will do with this truck, may not be an issue. I don't tow anything heavier than a 14' aluminum v-bottom much more than 10-15 miles 3-4 times a year, primary use of this truck is just gravel road travel once in a while. Aluminum bolt pattern adapters may be an acceptable issue just to get the sure-grip and greater strength of my 9 1/4? /although I have never been real comfortable using them in the past, I have never had an issue with them either. I'm just trying to get the better gear and sure-grip into this truck as easily and cheaply as possible.
Re: D-150 axle interchange [Re: tt76400] #1415619
04/07/13 01:46 AM
04/07/13 01:46 AM
New Richmond, WI
K
kams Offline
kams  Offline
K
New Richmond, WI
Only axle from 9 1/4 will work.
Re: D-150 axle interchange [Re: kams] #1415620
04/07/13 05:49 AM
04/07/13 05:49 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
have the 5X4.5 9 1/4 axles redrilled to the 5x5.5 pattern.. You will need a shorter driveshaft if you use your 9 1/4.
I am truckless..
Re: D-150 axle interchange [Re: kams] #1415621
04/07/13 10:00 AM
04/07/13 10:00 AM
scratchnfotraction Offline
on a 9 1/4 with SBP axles you CAN NOT just swap axle from another 9 1/4 that has the LBP axles.
they changed the c-clip/carrier in 85 when going to the LBP axles.
if you swap the carrier and axles then you are good to go.
like said,just find a 4x4 85-93 with the LBP axles and sg carrier.
Re: D-150 axle interchange [Re: scratchnfotraction] #1415622
04/07/13 10:52 AM
04/07/13 10:52 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The Large bolt pattern was brought back in 80 for the 4wds and in 85 the 2wds were changed over aswell. So why can't he use an early 4x4 axle? Also why's it have to be 4wd when 85 up were all 5x5.5" bp
Re: D-150 axle interchange [Re: 76dodgeboy] #1415623
04/07/13 09:56 PM
04/07/13 09:56 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Thanks for the info everyone, Isnt't the 8 1/4 and the 9 1/4 the same length from axle shaft centerline to u-joint centerline, thereby able to use the same driveshaft assuming the u-joint size is the same? I may just have to check into having the 9 1/4 axles redrilled, I never even though of that, is their enough "meat" to do that safely?
Re: D-150 axle interchange [Re: tt76400] #1415624
04/07/13 09:59 PM
04/07/13 09:59 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Yes to both questions. Axles were $221 ea from Chrysler when I was doing this.
Shortly after my swap meet 9.25 sure grip axle swap I broke the spider gears and took an axle with it.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: D-150 axle interchange [Re: 3hundred] #1415625
04/08/13 12:24 AM
04/08/13 12:24 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: D-150 axle interchange [Re: 340SHORTY] #1415626
04/08/13 05:01 PM
04/08/13 05:01 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Thanks for the info everyone! I'm either going to go with the billet spacers or just drill out my shafts for the larger bolt pattern I think, If it was just factory wheels, I'd just carry 2 spares, but since the truck has nice looking AR aluminum wheels on it, I'd like to keep them and keep the bolt pattern the same, I do need a sure-grip for sure in Iowa with our crappy winters!!!! Anybody want to trade a lbp sure grip with 3.23 or 3.55 gears for a sbp sure grip with 3.21 gears?
Re: D-150 axle interchange [Re: tt76400] #1415627
04/08/13 06:17 PM
04/08/13 06:17 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Why not buy an 8.75? Than get a sg for it? Im in western Iowa and have one not a sg but its a bolt in.
Re: D-150 axle interchange [Re: 340SHORTY] #1415628
04/08/13 11:22 PM
04/08/13 11:22 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Larry, I'm not following you, please explain?
Robert
'69 300 Convertible
'16 300 S Hemi
Re: D-150 axle interchange [Re: 3hundred] #1415629
04/09/13 01:16 PM
04/09/13 01:16 PM
dogdays Offline
dogdays  Offline
See the two 11.69"? One is the 8 1/4, the other is the 9 1/4.
R.
Re: D-150 axle interchange [Re: dogdays] #1415630
04/09/13 01:51 PM
04/09/13 01:51 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
R.
I know, I've done the 8.25 to 9.25 swap before. Larry seems to be indicating the driveshaft needs modification with the swap, then he posts a link to the chart that says no it doesn't. That's what I'm asking him about. It could be I'm missing something?
Robert
'69 300 Convertible
'16 300 S Hemi
Re: D-150 axle interchange [Re: 3hundred] #1415631
04/09/13 03:11 PM
04/09/13 03:11 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
He clearly states it needs shortened. Not sure on why he posted the link when it says no
Re: D-150 axle interchange [Re: 76dodgeboy] #1415632
04/09/13 04:26 PM
04/09/13 04:26 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I should of said "may" need to swap the driveshaft. I was thinking 8.75 instead of the 8 1/4 even tho I saw the 8 1/4 in print. For some reason my brain wasnt functioning right and I was thinking back when I swapped my 8 1/4 out for the 8.75 in my shorty . I posted the chart to clear up the subject . . Sorry for the confusion .
I am truckless..
Re: D-150 axle interchange [Re: 340SHORTY] #1415633
04/09/13 05:02 PM
04/09/13 05:02 PM
happens to me too shorty see one thing and say another.
Re: D-150 axle interchange [Re: scratchnfotraction] #1415634
04/09/13 06:11 PM
04/09/13 06:11 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
OAS old age syndrome
I am truckless..
