Re: D-150 axle interchange
[Re: kams]
#1415620
04/07/13 05:49 AM
04/07/13 05:49 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
have the 5X4.5 9 1/4 axles redrilled to the 5x5.5 pattern.. You will need a shorter driveshaft if you use your 9 1/4.
I am truckless..
[Re: kams]
#1415621
04/07/13 10:00 AM
04/07/13 10:00 AM
Posts: 15,487 Florida
scratchnfotraction
Only axle from 9 1/4 will work.
on a 9 1/4 with SBP axles you CAN NOT just swap axle from another 9 1/4 that has the LBP axles.
they changed the c-clip/carrier in 85 when going to the LBP axles.
if you swap the carrier and axles then you are good to go.
like said,just find a 4x4 85-93 with the LBP axles and sg carrier.
[Re: 340SHORTY]
#1415628
04/08/13 11:22 PM
04/08/13 11:22 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Larry, I'm not following you, please explain?
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 340SHORTY]
#1415633
04/09/13 05:02 PM
04/09/13 05:02 PM
scratchnfotraction
I should of said "may" need to swap the driveshaft. I was thinking 8.75 instead of the 8 1/4 even tho I saw the 8 1/4 in print. For some reason my brain wasnt functioning right and I was thinking back when I swapped my 8 1/4 out for the 8.75 in my shorty . I posted the chart to clear up the subject . . Sorry for the confusion .
happens to me too shorty see one thing and say another. ![](/ubbthreads/images/graemlins/blush.gif)
