How to measure oil level on manual valve body 727? #1415581
04/06/13 10:34 PM
04/06/13 10:34 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I want to measure the oil level on my 727 transmission.
It has a manual reverse pattern valve body and a trans brake.
Do you measure the oil level when idling in neutral like a stock 727?
Thanks!
Re: How to measure oil level on manual valve body 727? [Re: domingo] #1415582
04/06/13 10:42 PM
04/06/13 10:42 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
check in neutral like factory
Re: How to measure oil level on manual valve body 727? [Re: MPerry] #1415583
04/06/13 11:48 PM
04/06/13 11:48 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
hot idling in neutral?
OK will do thanks!
