489 case open rear to sure grip. I have some ???? #1415544
04/06/13 08:32 PM
04/06/13 08:32 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
I Have a 489 case center section open rear.. can it be rebuilt with a sure grip unit? and will it work in a housing axels and all that had a 741 case??
and what do the 489s usually come from?
here are some number from the ring gear 207011-3.23 MS 291 7-19-73
so i guess they are 3.23 gears built in 73
Don
Re: 489 case open rear [Re: Dakota_Don] #1415545
04/06/13 08:46 PM
04/06/13 08:46 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Yes and yes. Mid year 69 And later the 489 was the 8.75 pig.
Re: 489 case open rear [Re: Pacnorthcuda] #1415546
04/06/13 09:20 PM
04/06/13 09:20 PM
Alton, IL
Alton, IL
ok ty, ummmm what sure grip unit? can i use anything, or does it have to be a 489? and what types are best? and it will fit ok in a open pig housing and 741 rear housing
Re: 489 case open rear [Re: Dakota_Don] #1415547
04/06/13 09:23 PM
04/06/13 09:23 PM
Alton, IL
Alton, IL
thinking about this http://www.marketworks.com/StoreFrontPro...&i=18027296 and some 3.91 gears to rebuid my 741 into a 489
Re: 489 case open rear [Re: Dakota_Don] #1415548
04/06/13 10:50 PM
04/06/13 10:50 PM
Amherst,NY
challengermike Offline
Amherst,NY
you can use any case # suregrip in any # case, You just have to use the correct side carrier bearings for the case you are putting it in.The gears you can not interchange.
Re: 489 case open rear [Re: challengermike] #1415549
04/06/13 11:16 PM
04/06/13 11:16 PM
Alton, IL
Alton, IL
ok ty vm
Re: 489 case open rear [Re: Dakota_Don] #1415550
04/07/13 03:14 AM
04/07/13 03:14 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Call Cass (Moparts member: Dr. Diff) and tell him what you have and what you want and he'll set you up with everything you need.
