1970 to 1971 Cuda conversion #1415293
04/06/13 01:32 PM
04/06/13 01:32 PM
Clarksville, TN
RACERLEX Offline OP
RACERLEX  Offline OP
Clarksville, TN
Looking to change out the front grill and change a 70 Barracuda to a 71 Barracuda. I know certain things like header panel, front valance with insert, grill, etc.
I need help with what all in depth parts I need in the complete grill assembly, hardware, small pieces, and electrical to make this work. Please let me know where I can get all these parts as well.
I would appreciate your help on this one. Please refrain from your opinion if I should do the swap or not. Thanks!
Re: 1970 to 1971 Cuda conversion [Re: RACERLEX] #1415294
04/06/13 01:36 PM
04/06/13 01:36 PM
Kirkland, Washington
Pacnorthcuda Offline
OK...
Re: 1970 to 1971 Cuda conversion [Re: RACERLEX] #1415295
04/06/13 04:06 PM
04/06/13 04:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
As far as the headlamp forward harness, you could use the 70, just splice off the high beam leads, lamp pigtail connections are available so you can add the 4 headlamp set up, I've done it in the past, you'll need to lengthen the directional leads also, you'll need the 71 header panel, it is a one year only application, although you could use the 72-4 panel too, but the grille mounting tabs won't line up to the holes. you'll have a little drilling/filling if going with the 72-4 header, Fenders?,...what are you doing?, personally I'd go with the AMD 71 gilled Cuda fenders, lot of BS if your going to weld in louver patch/panels in your 70's,...you'll need the 71 only quad headlight brackets for the buckets onthe fenders to mount the headlights...
As far as the interior, depending on how "correct" you want it, the 71-4 steering column has the key lock tab on the ignition, as the 70 dosen't, the dash pad is the same 71-4 Cuda/Challenger, where as the 70 pads are body/year specific, seats also, depending on how correct your going, tailights, easy swap in, seatbelts changed in 71 also, I know some frown on this swap, but for some it's just another mod, do what floats your boat man!
Your best off listing what you need or have so that others can point you in the direction of parts required
Mike
Re: 1970 to 1971 Cuda conversion [Re: DAYCLONA] #1415296
04/06/13 04:48 PM
04/06/13 04:48 PM
Clarksville, TN
RACERLEX Offline OP
RACERLEX  Offline OP
Clarksville, TN
Thanks for the input. I am trying to focus mainly on the front grill section. There are a lot of specific parts focused in front grill and valance area that I will need....mostly around the headlight area. I need all those parts but I need to know what they are and where I can get them.
Re: 1970 to 1971 Cuda conversion [Re: RACERLEX] #1415297
04/07/13 03:56 AM
04/07/13 03:56 AM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
PG Classics or BE and A should have what you need, last I looked.
'71 SSP - SOLD!
