race car voltage *DELETED* #1415291
04/06/13 12:41 PM
04/06/13 12:41 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
Post deleted by Plymouth340
Re: race car voltage [Re: Plymouth340] #1415292
04/06/13 01:04 PM
04/06/13 01:04 PM
Normal voltage is 13 something to 14 something & you're well above that even at idle. I'm sure 18 at WOT will give you more power but it may or may not burn something out & may or may not significantly shorten its lifespan. Tho for short periods you can get by with alot. If longevity is an issue I'd maybe consder a different reg
