Page 3 of 4 1 2 3 4
Re: What brand oil filters do you use? [Re: ahy] #1415163
04/07/13 01:19 AM
04/07/13 01:19 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
MOPAR
Re: What brand oil filters do you use? [Re: Abodysforever] #1415164
04/07/13 01:45 AM
04/07/13 01:45 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Fram HP-1, 35 years of Fram and no failures. Have taken the race engine apart every winter since I have been doing this and the bearings look as good as the day I put them in. This has raised my curiousity level so I did a little research.
Looking at what microns some of the filters actually filter. Wix being the worst at 60 microns and K&N being the best at 10 microns, Fram comes in at 18 microns. Oberg style filters at 60 and System One style comes in at 30. So if your really concerned about the internals of a filter put one of these on...no paper and a one time cost, no more buying filters!
As far as cost? On Summits website all racing/spin on type filters are within a couple bucks of each other.
Re: What brand oil filters do you use? [Re: loaderpro] #1415165
04/07/13 03:47 AM
04/07/13 03:47 AM
SE PA
Yellow Fever Offline
SE PA
Wix or if I need one quick locally, Purolator. My brother in-law lost a newly built BB chebbie motor due to the fram coming apart. He was warned but didn't heed the warnings.
Re: What brand oil filters do you use? [Re: Yellow Fever] #1415166
04/07/13 03:57 AM
04/07/13 03:57 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
at 1 point the mopar filters were made byfram
Re: What brand oil filters do you use? [Re: 05dakota] #1415167
04/07/13 04:52 AM
04/07/13 04:52 AM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Anything but Fram....I was told Purolator makes Mopar now.Either one ate good products.
Re: What brand oil filters do you use? [Re: bee71mopar] #1415168
04/07/13 09:56 AM
04/07/13 09:56 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mopar
Re: What brand oil filters do you use? [Re: justinp61] #1415169
04/07/13 01:32 PM
04/07/13 01:32 PM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
Been using Motorcraft for years, on everything I've owned.
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
Re: What brand oil filters do you use? [Re: wildman340] #1415170
04/07/13 03:11 PM
04/07/13 03:11 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
WIXX!!
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: What brand oil filters do you use? [Re: cogen80] #1415171
04/07/13 03:40 PM
04/07/13 03:40 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
Napa Gold/Wix
Same here
Re: What brand oil filters do you use? [Re: Valiant_Showoff] #1415172
04/07/13 08:20 PM
04/07/13 08:20 PM
North Austin
KnuckleDuster Offline
North Austin
Wix on the Duster,big honkin K&N on my 85 318 truck!
Re: What brand oil filters do you use? [Re: KnuckleDuster] #1415173
04/08/13 10:18 AM
04/08/13 10:18 AM
Lexington NC
twinscrew698 Offline
Lexington NC
Baldwin Filters in all of mine!
Re: What brand oil filters do you use? [Re: Abodysforever] #1415174
04/09/13 01:24 PM
04/09/13 01:24 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I generally use hastings. Sometimes hard to find, worth buying 6 or 12 off the internet and keep my own stock. Fortunately three of my vehicles use the same filter. Here is a little write-up and link that I found interesting. Also hastings site has a lot of info about media, micron ratings, and more importantly in filter bypass.
Some vehicles handle by-pass in the motor, some need a by-pass in the filter.
http://www.efficient-mileage.com/oil-filters.html
Choose an Oil Filter by brand
Purolator, Mobil1, Motorcraft, Mann, and Amsoil.
(and Supertech which is the Walmart brand if you're really on a tight budget)
That's it. It's a short list. That makes it easy to remember.
Purolator Pure One and K&N oil filters are decent. However the media seems dense enough to impede the passage of oil. Those filters are built well.
MANN+HUMMEL & Bosch own Purolator as of 2006. Purolator was previously an ArvinMeritor product and considered to be one of the finest oil filters in the business. MANN+HUMMEL also make oil filters for the German car manufacturers, BMW, Audi, and Porsche. I'm impressed by the construction of the Mann filter. Bosch outsources their oil filters to Champion Labs. And the Bosch filters are awful.
Hastings manufactures Amsoil, Baldwin, and Hastings oil filters. All good stuff.
Champion Labs produces oil filters under a variety of names. Those include Fram, STP, SuperTech, Delphi, Bosch, Mobil1, K&N, AC Delco, and a few others too insignificant to mention. There's a lot of Good, Bad, and Ugly in there.
Notes:
amsoil specs a media not made by hastings (who may use outside manufacturers for their media as well?).
**wix is not mentioned above and:
NAPA Gold AND CarQuest Premium ARE the regular Wix.
The lower series of NAPA are made by Wix, but are a little lower quality.
I think it more important to chose a good filter you are cmfortable with and know the vehicle it is running. An occasional oil analysis might lead to extended change intervals, but should not be relied on. An poorly tuned older carbureted vehicle is going to need more frequent changes than a new efi or well tuned older vehicle.
Diesel will always require short interval changes.
Re: What brand oil filters do you use? [Re: srt] #1415175
04/09/13 02:12 PM
04/09/13 02:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Notes:
I was beginning to think I was the only one using Hastings, I knew they were a good filter because they are not the cheapest and sold by real hard core parts store. Not a retail type filter.
Re: What brand oil filters do you use? [Re: Challenger 1] #1415176
04/09/13 11:23 PM
04/09/13 11:23 PM
Detroit, Mi
michiganhotrod1 Offline
Detroit, Mi
Mopar (but I worked there and I'm biased). No matter what supplier made them, Chrysler Engineering had to sign-off on the supplier, and they did not want to be dinged with extra engine warranty expense. They were pretty tight on this!
Mark
Re: What brand oil filters do you use? [Re: michiganhotrod1] #1415177
04/09/13 11:30 PM
04/09/13 11:30 PM
St. John's Newfoundland
440newport Online content
440newport  Online Content
Wix filters usually have 6 drain back holes. Napa Golds used to have 6 holes like the Wix too, but the last couple I bought have 8 holes which makes me think they may have changed suppliers?
Re: What brand oil filters do you use? [Re: michiganhotrod1] #1415178
04/09/13 11:31 PM
04/09/13 11:31 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
wix
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: What brand oil filters do you use? [Re: cogen80] #1415179
04/09/13 11:57 PM
04/09/13 11:57 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
wix or purolator
Mike
1969 Dodge Dart Swinger
Re: What brand oil filters do you use? [Re: MikeyT] #1415180
04/10/13 12:19 AM
04/10/13 12:19 AM
NY NY
3
340duster340 Offline
NY NY
stp, cheap and made in USA
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: What brand oil filters do you use? [Re: 440newport] #1415181
04/10/13 12:44 AM
04/10/13 12:44 AM
southern Idaho
moparcyco Offline
moparcyco  Offline
southern Idaho
I work for Napa,Wix still supplies all of our filters.If you can most places that carry wix have a farm sale snd you can buy them much cheaper.
Re: What brand oil filters do you use? [Re: moparcyco] #1415182
04/10/13 03:31 PM
04/10/13 03:31 PM
dogdays Offline
dogdays  Offline
I admit, I didn't read the previous posts. But, I am working on a new lubrication system for our hydroelectric plant and have come up with some things worth passing on:
1. You probably aren't going to see outright failures with any filter, the lubrication systems are pretty good. Especially if you are running an air filter, because road dirt is a real problem when ingested.
So this means that any filter that doesn't blow up or leak is most likely going to seem okay.
2. If you want to improve your engine's oil filtration, you should be using a filter made with SYNTHETIC FIBERS. That's the key. Most $10 oil filters have synthetic fibers.
But remember, as you weren't having any outright failures before, the new filters are not going to make any short-term difference.
One may see a reduction of wear over the years. Recent research shows that particles, much smaller than the distance between bearing and journal, can and do cause wear.
If one really wanted clean oil, then a "kidney loop" filtration system with a 5 micrometer (micron) absolute particle size would be the answer. Then one could run almost any oil filter and the oil would still be clean, cleaner than it is now.
R.
People get all bent out of shape about oil and filters. I'm not going to bother reading any replies because it's sort of like religion. But synthetic fibers are the key, if you're interested in reality.
Page 3 of 4 1 2 3 4
