Page 2 of 4 1 2 3 4
Re: What brand oil filters do you use? [Re: HotRodRailroader] #1415143
04/06/13 04:10 PM
04/06/13 04:10 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Wix or Purolator
Re: What brand oil filters do you use? [Re: Aero426] #1415144
04/06/13 04:13 PM
04/06/13 04:13 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Mopar
Re: What brand oil filters do you use? [Re: Abodysforever] #1415145
04/06/13 04:45 PM
04/06/13 04:45 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Standard white PurOLator
Nautilus Racing-
Re: What brand oil filters do you use? [Re: Abodysforever] #1415146
04/06/13 05:29 PM
04/06/13 05:29 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
here ya go.. some common filters cut open to help ya make a decision..
http://www.abodyjoe.com/Misccars/carinfo/oilfilters/oilfilters.htm
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: What brand oil filters do you use? [Re: abodyjoe] #1415147
04/06/13 06:02 PM
04/06/13 06:02 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I use Wix or the white Canadian Mopar filters which are also made by Wix.
Napa Golds used to be Wix too but are now made by Fram I believe.
Re: What brand oil filters do you use? [Re: 440newport] #1415148
04/06/13 07:17 PM
04/06/13 07:17 PM
Detroit, Michigan
fjr340gts Offline
fjr340gts  Offline
Detroit, Michigan
WIX only.......
Re: What brand oil filters do you use? [Re: fjr340gts] #1415149
04/06/13 07:27 PM
04/06/13 07:27 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
WallyWorld ferr me ...
And to you Fram haters ..... 'splain to me please ...if their stuff was such garBAGE .... and have messed up so many engines ..... WHY hasn't Fram been sued into bankruptcy ?
Re: What brand oil filters do you use? [Re: dOoC] #1415150
04/06/13 07:33 PM
04/06/13 07:33 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
And to you Fram haters ..... 'splain to me please ...if their stuff was gar-bage .... and have messed up so many engines WHY hasn't Fram been sued into bankruptcy ?
Because when one fails and it lets crap pass the filter it only causes needless wear on the engine, not catastrophic failure.
I ve used Walmart filters and I think they are ok, but their cans are pretty thin and bend easy. I stopped buying them when I discovered that.
Wix for me. Gave up on Fram over 20 years ago!
Re: What brand oil filters do you use? [Re: dOoC] #1415151
04/06/13 07:38 PM
04/06/13 07:38 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I know this is blasphemy in the face of ALL that are logical...............
but I use the standard Fram on my wifes 04 Durango. It's got 154k miles on it now and it hasn't yet kicked the rods outta the block!!
And she doesn't spare it any either. But I've also been told that I change the oil too often (3500-4k) and the filter gets changed then too.
Re: What brand oil filters do you use? [Re: Dean_Kuzluzski] #1415152
04/06/13 08:04 PM
04/06/13 08:04 PM
Florida STAYcation
Florida STAYcation
DeanO .... I have that UPgraded Fram on my daily-driver right-now .....with that sprayed on grip ....SO I can R&R-it and dump the oil in it and use-it AGAIN !! ...
Re: What brand oil filters do you use? [Re: Abodysforever] #1415153
04/06/13 08:21 PM
04/06/13 08:21 PM
PA
KGorney Offline
KGorney  Offline
PA
I use Wix or Napa Gold for all my vehicles.
Re: What brand oil filters do you use? [Re: dOoC] #1415154
04/06/13 08:22 PM
04/06/13 08:22 PM
You probably re-use toilet paper...
Re: What brand oil filters do you use? [Re: Pacnorthcuda] #1415155
04/06/13 08:30 PM
04/06/13 08:30 PM
GA
Boosted Offline
Boosted  Offline
GA
Fram HP1
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: What brand oil filters do you use? [Re: Boosted] #1415156
04/06/13 08:32 PM
04/06/13 08:32 PM
Fram HP1
Only thing wrong with an HP1 is the price!
Re: What brand oil filters do you use? [Re: Pacnorthcuda] #1415157
04/06/13 08:57 PM
04/06/13 08:57 PM
Florida STAYcation
Florida STAYcation
No I don't PACman ... butt I do package-up the used-stuff and send it to the TREEhuggers(freight charges collect) in KIRKville WA ...
THEY reuse it ....
Re: What brand oil filters do you use? [Re: Abodysforever] #1415158
04/06/13 09:16 PM
04/06/13 09:16 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
i use FVP brand, its made by wix
Re: What brand oil filters do you use? [Re: Dakota_Don] #1415159
04/06/13 09:55 PM
04/06/13 09:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've got an AC Delco on my wifes Sebring. It just started making a fairly loud ticking noise. By the looks of that filter in the above link, it has cardboard end caps too. I need to get that off of there ASAP. I usually run CarQuest blue filters.(Wix)
Re: What brand oil filters do you use? [Re: burdar] #1415160
04/06/13 10:00 PM
04/06/13 10:00 PM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
wix
Re: What brand oil filters do you use? [Re: m88mark] #1415161
04/06/13 10:31 PM
04/06/13 10:31 PM
montana
P
pjc360 Offline
pjc360  Offline
P
montana
napa gold wich is wix, car quest blue wich is wix and wix, wichever one is cheaper when i need one, all 3 are the same filter. Main reason i like wix the best is cause they have the best anti drain back valve and set up of all the filters i have cut open.
I normally like to buy the car quest blue filters the most because they are white and its easy to tell if any oil is leaking at the filter. But i have cut open a napa gold, and a car quest blue and a name brand wix and all 3 are identical, only difference is the color and the stickers on the filter.
Re: What brand oil filters do you use? [Re: pjc360] #1415162
04/06/13 11:34 PM
04/06/13 11:34 PM
IN
ahy Offline
ahy  Offline
IN
MOPAR (from Walmart) on DD's. NAPA premium or K&N on others.
Page 2 of 4 1 2 3 4
