65Dart to 73Dart Disc upgrade.
#141509
10/25/08 11:04 PM
10/25/08 11:04 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
From my 73 Dart Sport after my Wilwood swap, I have new factory calipers,pads and rotors left over. Id like to donate them to a friend with a 65 Dart convertible that currently has the stock drums. What would it take to be able to swap these parts on to his car. Can this be done Or is there a much easier way to upgrade his front brakes thanks mike
Re: 65Dart to 73Dart Disc upgrade.
[Re: Sport440]
#141510
10/25/08 11:22 PM
10/25/08 11:22 PM
RapidRobert
I have new factory calipers,pads and rotors left over. What would it take to be able to swap these parts on to his car. mike
73 up A body(or any F body) spindles,caliper adapters(these are sliders)(& the big bolts),splash shields are nice, volare F body hoses, correct(ribbed) hose washers, bearings,seals, spindle nut,nut retainer cage, Mount the calipers to the front(makes for no hose problems,just use the volare hoses. pad retainer clips & bolts. 73 up A body UCA's.
[Re: Sport440]
#141511
10/25/08 11:24 PM
10/25/08 11:24 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
What would it take to be able to swap these parts on to his car. Or is there a much easier way to upgrade his front breaks. mike
Read this:
http://www.moparaction.com/tech/archive/disc-main.html
The major things he needs:
-73-76 Upper A-arm with the larger ball joint (disc brakes or 10" drum applications) -73-76 lower ball joints -large bolt pattern front rims -disc brake master cylinder -adj rear proportioning valve -if you run the calipers in the rear for a sway bar application you need banjo type brake flex line (forgot car they come from)
[Re: Sport440]
#141513
10/27/08 01:22 PM
10/27/08 01:22 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
I used the www.scarebird.com disc brake swap bracket, then i went to napa,advance or autozone and purchaced all new or rebuilt parts.. the swap took about 3.5 to 4 hrs to do.. and i didnt have to change out my spindles or a-arms.. the only problem i had was, I had to use a redisual valve for the rear drum brakes.. they stop great even for manual brake system..
