312 and 902 heads...what's the difference??? #1415073
04/06/13 01:57 AM
04/06/13 01:57 AM
Vancouver,Canada
70 Roadrunner* Offline OP
Vancouver,Canada
Guys I'm wondering how similar 312 heads are compared to 902 heads and can they be run on the same engine? The 312 on one side and the 902 on the other?Identically prepped springs/valves...etc. Maybe someone can help me out...thanks
Re: 312 and 902 heads...what's the difference??? [Re: 70 Roadrunner*] #1415074
04/06/13 10:10 AM
04/06/13 10:10 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
312?? never heard of it?
http://www.mymopar.com/headcastnumb.htm
numbers
http://www.moparmusclemagazine.com/techarticles/5115_cylinder_heads/viewall.html
You should pick one place or another to ask questions here not two but oh well! A gave same answer in questions and answers!
Re: 312 and 902 heads...what's the difference??? [Re: Dodgem] #1415075
04/06/13 10:50 AM
04/06/13 10:50 AM
Vancouver,Canada
Vancouver,Canada
I'm bloody dyslexic...the one head is 3751213...I'll only post in one section from now on...lesson learned
Re: 312 and 902 heads...what's the difference??? [Re: 70 Roadrunner*] #1415076
04/06/13 12:24 PM
04/06/13 12:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
the motor will not know vertually the same. I once unknowingly had a pair of 906 heads with .030 more milled off one then the other and could not tell. when I found it a couple years later milled .050 of one and .020 off the other to make them even!
Re: 312 and 902 heads...what's the difference??? [Re: Dodgem] #1415077
04/08/13 03:56 AM
04/08/13 03:56 AM
Vancouver,Canada
Vancouver,Canada
Dodgem thanks for the reply...I was hoping for some good news.I've made my share of mistakes on this project so far but these two heads should work fine.Very much appreciated...
