Small block bracket car machine work price #1415043
04/05/13 11:18 PM
04/05/13 11:18 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Local guy had a local guy
clean block
bore
align bore
install cam bearings
$2300.00
Uff da !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Small block bracket car machine work price [Re: bigdad] #1415044
04/05/13 11:20 PM
04/05/13 11:20 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
He treated them like a tourist by the sound of things. I have a couple choices up here who have good reputations , plenty of their stuff running every week end and they would all come in significantly cheaper.
Re: Small block bracket car machine work price [Re: tubtar] #1415045
04/05/13 11:26 PM
04/05/13 11:26 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
2nd report I have heard about his practices
charged one guy
$36.95 for a fuel pump block off
($20.00 freight )was part of the charges
Re: Small block bracket car machine work price [Re: bigdad] #1415046
04/06/13 08:57 AM
04/06/13 08:57 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I don't expect work or parts for free , but I really hate the folks who try to retire on every sale.
S&H is the most common gouge in on line sales and among the worst at it is.........drum roll please................Goodwill industries.
I shop for knives on there , and to a store , they are brutal with their S&H.
If it wasn't for the charitable aspect and the fact that I have gotten some really odd ball stuff , I would really be upset with them.
The last time I had machine work done , I never thought to ask how much it would be. I had a ball park figure in mind and it came in almost to the dollar. Maybe a bit cheaper. And this was from a very good shop.
( R&R in Spring Lake Park , Mn. )
I just can't see a small market shop stealing that kind of money and expecting to stay in business long.
Re: Small block bracket car machine work price [Re: tubtar] #1415047
04/06/13 09:37 AM
04/06/13 09:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If he is the only game in town or surrounding area
he can charge higher but damn... $2300 for that
Re: Small block bracket car machine work price [Re: bigdad] #1415048
04/06/13 10:28 AM
04/06/13 10:28 AM
Maybe it is time to put that shops name on the net for business references, who to use and who NOT to use
Re: Small block bracket car machine work price [Re: bigdad] #1415049
04/06/13 11:46 AM
04/06/13 11:46 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Before we get to far into this we should see the invoice to know what all was really done. Like did they torque plate bore/hone, and maybe a special hone process. Did the shop install 4 bolt caps then align bore and were there any parts on the bill
Re: Small block bracket car machine work price [Re: SB412DUSTER] #1415050
04/06/13 12:27 PM
04/06/13 12:27 PM
jeff500 Offline
jeff500  Offline
Re: Small block bracket car machine work price [Re: jeff500] #1415051
04/06/13 12:28 PM
04/06/13 12:28 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
No extra parts, no 4 bolt caps
Re: Small block bracket car machine work price [Re: bigdad] #1415052
04/06/13 12:34 PM
04/06/13 12:34 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
That just cant be...I mean...that work, IF thats all that was done should be $550-$700 depending on where you live.
Can you get a invoice so we can see where this bill charges another $1600 ???? You can cover or white out the names, but damn.....there is no way they can charge an extra $1600 for that work...
RIP Monte Smith
Re: Small block bracket car machine work price [Re: CompWedgeEngines] #1415053
04/06/13 12:40 PM
04/06/13 12:40 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I might be able to
Guy that got honked is kinda shy, don't think he would want too much attention
Re: Small block bracket car machine work price [Re: bigdad] #1415054
04/06/13 01:38 PM
04/06/13 01:38 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I'd be a little embarrassed over it , but not nearly as much as having my name in the Sioux Falls gazette for rat stomping this crook for gouging me.
The press never wants to know why.......just who.
I considered " did he use a plate " but didn't factor parts.
But there aren't many parts involved unless he bought pistons from him , I am not seeing much else.
Shop supplies ?
Re: Small block bracket car machine work price [Re: bigdad] #1415055
04/06/13 01:40 PM
04/06/13 01:40 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I'll see if can dig up more info
Re: Small block bracket car machine work price [Re: bigdad] #1415056
04/06/13 02:00 PM
04/06/13 02:00 PM
Guitar Jones Offline
Wow. I had my block hot tanked, shot blasted, hard block filled, align honed, bored with a plate, square decked, rotating assembly balanced, cam, main and rod bearings, main caps machined and girdle installed plus bought Wiseco custom pistons and pins for $2200.
I knew I got a pretty good deal but not that good. That's outrageous.
