scratches on side of hydraulic lifter.. #1415040
04/05/13 11:16 PM
04/05/13 11:16 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
I had to pull my heads due to bent valves caused by the dowel coming out of my cam and the pistons hitting them.
Anyway I noticed this after pulling the intake. One of the lifters has scratches around the outside of it. The scratch certainly isn't deep but I can feel it with my fingernail. It seems the scratch is below the level of where the lifter comes up into the bore-- or maybe right on the edge. None of the bent valves were on this side, so I don't think that caused this.
What would cause this? This lifter, and the others, move/spin freely in the bore. I checked this one even with the lifter at various 'lifts' and it will rotate.
Should I do anything? (other than remove the antifreeze from the galley)?
Re: scratches on side of hydraulic lifter.. [Re: Exit1965] #1415041
04/05/13 11:55 PM
04/05/13 11:55 PM
Don't sweat the petty stuff, run it Look at the bottom of that lifter, if it shows a circular rotation your golden
Re: scratches on side of hydraulic lifter.. [Re: Cab_Burge] #1415042
04/06/13 12:28 PM
04/06/13 12:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Seen way worse............Also; Jason Pettis used to grind a flat section on my flat tappets about .125 wide from top to bottom for extra oiling............
