oversized wheel studs with stock wheels? #1414964
04/05/13 03:59 PM
04/05/13 03:59 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
With stock steel wheels, can you use 9/16 or 5/8 studs? Will it increase the stength, or will the size of the tapered hole that the nut fits into limit the strength anyway?
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: oversized wheel studs with stock wheels? [Re: Hemi_Joel] #1414965
04/05/13 04:21 PM
04/05/13 04:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks, Joel
I cant say for fact but myself I wouldnt bore them
out to fit a larger stud... plus if you did you would
need to bore out the axles... they are pretty stout
to bore out....... JMO
Re: oversized wheel studs with stock wheels? [Re: MR_P_BODY] #1414966
04/05/13 05:01 PM
04/05/13 05:01 PM
Minnesota
Minnesota
Thanks Mr. P. The thing is, I am going to be ordering a set of axles. If I am going to upgrade the studs, now is the time...
Re: oversized wheel studs with stock wheels? [Re: Hemi_Joel] #1414967
04/05/13 05:44 PM
04/05/13 05:44 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
PM Mike Crow(73fish) at Bangshift.He put bigger studs in his Magnum wheels on his Cuda and also his Dart.
Re: oversized wheel studs with stock wheels? [Re: Hemi_Joel] #1414968
04/05/13 05:46 PM
04/05/13 05:46 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
How fast do you plan on going? A good set of 1/2" studs are pretty stout!
67' charger 499 RB 10.57 at 127
Re: oversized wheel studs with stock wheels? [Re: dragram440] #1414969
04/05/13 06:07 PM
04/05/13 06:07 PM
Minnesota
Minnesota
3000 lb car, eventually plan to get it into the 9's with a manual trans.
I hate breaking stuff, I'd rather build it stout to begin with.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: oversized wheel studs with stock wheels? [Re: dragram440] #1414970
04/05/13 06:10 PM
04/05/13 06:10 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
I just did the same thing with a set of american racing torque thrusts and they are super tight with the 5/8 stud at 4-1/2 bolt pattern. Main problem is the nut for the 5/8 studs. its a flange nut with an o.d. of 1.2900 and the hole in the wheel is only 1.200. im making my own nuts and spacers so it wasn't a big deal but something to think about
