oversized wheel studs with stock wheels?
#1414964
04/05/13 03:59 PM
04/05/13 03:59 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
With stock steel wheels, can you use 9/16 or 5/8 studs? Will it increase the stength, or will the size of the tapered hole that the nut fits into limit the strength anyway?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: oversized wheel studs with stock wheels?
[Re: Hemi_Joel]
#1414965
04/05/13 04:21 PM
04/05/13 04:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks, Joel
I cant say for fact but myself I wouldnt bore them out to fit a larger stud... plus if you did you would need to bore out the axles... they are pretty stout to bore out....... JMO
[Re: Hemi_Joel]
#1414968
04/05/13 05:46 PM
04/05/13 05:46 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
How fast do you plan on going? A good set of 1/2" studs are pretty stout!
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1414969
04/05/13 06:07 PM
04/05/13 06:07 PM
Hemi_Joel
Minnesota
3000 lb car, eventually plan to get it into the 9's with a manual trans. I hate breaking stuff, I'd rather build it stout to begin with.
