Eagle heads ordered! edit; the final story!
#1414944
04/05/13 03:51 PM
04/05/13 03:51 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Lets hope the order comes through as the confirmation said, $305.47 each, plus freight to my door of $61. I went this way on the 5.7 stroker build simply because I want a new head with new parts, and figure after I sell the 5.7 cores, the deal can't be beat! The part numbers have been superseded. 53021608dd is rl021608dd 53021609dd is rl021609dd :edit Well Ma Mpoar got into our pants a little deeper with the latest price jump on the eagle heads. The instant I posted this I got a call from the seller, Dodgeparts.com with the good news. The part number changed, and so did the price, plus there is an added core charge! I am waiting for the new order, to see the actual total. I was quoted an additional $590 total for them to my door. I have to OK the sale by Email, so I now have a chance to think about it a bit.
Re: Eagle heads ordered! Cheap!
[Re: gregsdart]
#1414945
04/05/13 03:56 PM
04/05/13 03:56 PM
Guitar Jones
Those are reman numbers. What was the core charge and who did you order them from?
[Re: gregsdart]
#1414948
04/05/13 04:13 PM
04/05/13 04:13 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Dodgeparts.com So I am not getting new castings? Any chance of problems?I figured that I would be getting loaded heads.
No these are new parts, The RL signifies they are released to increase or establish a core bank.
[Re: sixpackgut]
#1414950
04/05/13 04:32 PM
04/05/13 04:32 PM
gregsdart
The $590 also includes the added core charge, which I will have to pay. My one concern; are the new part numbers bare castings, with valves, or fully loaded with everything?
[Re: gregsdart]
#1414951
04/05/13 04:37 PM
04/05/13 04:37 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
They'll come fully assembled. I started with never used cores on my ported eagles. Left factory valves and only upgraded springs/shims/seals.
[Re: Seth_Jones]
#1414953
04/05/13 04:56 PM
04/05/13 04:56 PM
gregsdart
I just sent them a response, as needed to process the order with the new numbers. If they are loaded, I want them. If not, I may as well work with the early heads I have, and hope they are good when I pull them off to look.
[Re: gregsdart]
#1414954
04/05/13 05:05 PM
04/05/13 05:05 PM
gregsdart
I got my answer; they must come bare, as they cancelled the order like I asked if the castings are bare. Sooooooooooo, the early 5.7s will have to do, at least that is the plan. This a a bit of a heart breaker, from 305 per for assembled heads, to $600 for bare castings (includes core charge)
[Re: rt66jim]
#1414956
04/05/13 05:53 PM
04/05/13 05:53 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I can get Apache heads for under 500 each. No core charge either.
Mopar to the bone!!!
[Re: 72Swinger]
#1414957
04/06/13 10:30 AM
04/06/13 10:30 AM
gregsdart
I checked out all the info given here, thanks for the info guys. The last word is, over $1200 for a new set of eagles now if you have no cores. What a bummer. So back to plan A, get my cores checked when I get home and see what it will cost to have them done up for what I need.
[Re: gregsdart]
#1414958
04/06/13 10:45 AM
04/06/13 10:45 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Heres a question do they put out reman part for all the core they replace due to waranty issues. Lets face it with the price of labour it cheaper to replace an entire engine instead of finding out what went wrong. So the get a bunch of core engines, figure out what they can salvage and put it out as a Reman part # until exhausted. If this is true then new heads shouln'd be coming down the line?
[Re: MattW]
#1414959
04/06/13 02:29 PM
04/06/13 02:29 PM
Guitar Jones
Sometimes new parts are sold as remans, some parts like torque converters for instance can't be purchased new, they are all remans.
But, the majority of the time you still have to find out what went wrong before you can replace an entire engine. Mopar has or at least had, a 70% rule. If it cost 70% of an assembly to repair, then you replace it.
[Re: hemidup]
#1414962
04/06/13 05:39 PM
04/06/13 05:39 PM
MattW
Ontario Canada
Here's an example of a ported 5.7 head with 2.05"/1.57" valves vs a ported 6.1 head with 2.08"/1.60" valves. Even though the ported 6.1 heads flowed higher #s on the bench, the dyno and track times proved different. Just saying
Thanks for the info
with you but would there be a benefit for the other G3 heads. I would assume as the CID increases, more air being pulled through the port, the bigger heads would work more efficiently. It would be nice to know at what CID the eagle head would come into play. I'm thinking anything over 430 cid.
Once again Thanks Jerry for all your help. Matt
