intake valley pan cracked
#1414745
04/05/13 12:52 AM
04/05/13 12:52 AM
Posts: 76 california
hornetnut
california
so i noticed some oil on the valley pan and upon closer inspection i noticed several small cracks right on the middle of it, is this common? should i be worried? its a 67 440 with eddy heads and eddy performer rpm intake
Re: intake valley pan cracked
[Re: hornetnut]
#1414746
04/05/13 12:59 AM
04/05/13 12:59 AM
RapidRobert
Not too common. Ma put that fiberglass mat in there to stop vibrations from cracking it. Me I'd go ahead & replace it
[Re: challengermike]
#1414749
04/05/13 09:35 AM
04/05/13 09:35 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I had a breather and PCV valve on my big block. a WOT blast would pop the dipstick out of the tube, and I cracked 2 of those pans.
took my breather out and examined it more closely. it was difficult to blow through it, the opening was barely punched open, and resembled the butterfly of a carb that was cracked open for a fast idle. I punched it out, and tried again. this time the filter element was so thick that it was still a struggle to blow through it.
I removed the dense thick filter stuff and put some very lightweight foam in there.
no more popped dipstick and no more cracked pans.
**Photobucket sucks**
