isky red zone lifters 3772-lo-180-ezx #1414688
04/04/13 09:52 PM
04/04/13 09:52 PM
new york usa
P
pattyboy 572 Offline OP
P
new york usa
I check the search, did not find my answer, when ordering these lifters ,must you specify that you are using push rod oiling.... or are they already set up for that option. thank you pat
Re: isky red zone lifters 3772-lo-180-ezx [Re: pattyboy 572] #1414689
04/05/13 10:17 AM
04/05/13 10:17 AM
new york usa
P
P
new york usa
help
Re: isky red zone lifters 3772-lo-180-ezx [Re: pattyboy 572] #1414690
04/05/13 01:19 PM
04/05/13 01:19 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Can't say for sure whether you'll have a choice. Most lifters are either one or the other and will specify which. Any quality lifter, such as these, likely has pushrod oiling. My suggestion, if they give you a choice, would be to order them with pushrod oiling whether you currently need it or not. There is no downside.
Re: isky red zone lifters 3772-lo-180-ezx [Re: pattyboy 572] #1414691
04/05/13 10:29 PM
04/05/13 10:29 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
I have 3372-lo-180 with the ez option and they are pushrod oiling.I believe if yours are pushrod oiling it will have a orifice on the body for the pushrod oiling, and one down by the roller for the ez bearing.
Re: isky red zone lifters 3772-lo-180-ezx [Re: Twin Turbo Mower] #1414692
04/05/13 11:09 PM
04/05/13 11:09 PM
new york usa
P
P
new york usa
only two small holes down by the roller ,none on the body? (one on each side of lifter body)
Re: isky red zone lifters 3772-lo-180-ezx [Re: pattyboy 572] #1414693
04/05/13 11:18 PM
04/05/13 11:18 PM
Mt.Vernon IL
Mt.Vernon IL
Yeah sounds like you got the version that just oils the roller. Are they new? You can call the isky guys and they will exchange them for you if they are. You will just have to pay shipping.
Re: isky red zone lifters 3772-lo-180-ezx [Re: Twin Turbo Mower] #1414694
04/05/13 11:28 PM
04/05/13 11:28 PM
new york usa
P
P
new york usa
yes got em yesterday
Re: isky red zone lifters 3772-lo-180-ezx [Re: Twin Turbo Mower] #1414695
04/08/13 04:36 PM
04/08/13 04:36 PM
new york usa
P
P
new york usa
Thanks for the heads up , called isky today ,they will gladly exchange them for the correct ones...like u said the freight is on me ,no problem...it must be specified when ordering...PUSH ROD OILING.
