small block head guide pins? #1414446
04/04/13 02:17 PM
04/04/13 02:17 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Hello. Starting to put together a 71 340. I noticed that neither the heads nor the block have guide pins as many other motors do. Did it ever have them or do I need them? I took apart a 318 and it didn't have them either. I thought they would be necessary for alignment. Thanks
Re: small block head guide pins? [Re: dan9] #1414447
04/04/13 02:20 PM
04/04/13 02:20 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
They should be there in the block , if the block was decked the shop didn't replace them.
But be careful they are NOT .250 dowels , more like .246 .
Re: small block head guide pins? [Re: JohnRR] #1414448
04/04/13 02:31 PM
04/04/13 02:31 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
Wow thanks. I guess i'll have start looking for a place to get them.
Re: small block head guide pins? [Re: dan9] #1414449
04/04/13 02:32 PM
04/04/13 02:32 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
Im about 99% positive the SB chevy ones work. I bought a 318 that didnt have them either and I put them in when I put it back together. Pretty sure those are the ones I used.
Re: small block head guide pins? [Re: Baxter61] #1414450
04/04/13 06:15 PM
04/04/13 06:15 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
You are correct. Small block Chevy are the same. The .246 ones are for timing covers. Luckily for me a local engine builder had them. Thanks to all for your help.
Re: small block head guide pins? [Re: dan9] #1414451
04/04/13 07:02 PM
04/04/13 07:02 PM
Are the .246" ones for timing covers and decks
Re: small block head guide pins? [Re: RapidRobert] #1414452
04/05/13 02:07 PM
04/05/13 02:07 PM
pa.
dan9 Offline OP
dan9  Offline OP
pa.
The guy at the engine shop said the .246 ones were for timing covers. I didn't check to see if he was right.
