´67 Barracuda wiper switch and wiper motor... #1414422
04/04/13 12:56 PM
04/04/13 12:56 PM
FINLAND
Heimo572 Offline OP
Heimo572  Offline OP
FINLAND
Having a problem with wipers. Took a wiper motor from ´67 Belvedere which I believe to be 2-speed (red, blue and brown wire). Then I have a switch and think it might be 3-speed (7 wires) but I can only find "two klicks" from it. Wipers only work sometimes in left position, in middle and right position nothing happens. Mostly wipers dont work at all from the switch.
Could I have bad or wrong switch or even wrong motor for barracuda ? In wiring diagram there seems to be red, blue, brown and green wires going to wiper motor and wiring to switch is just like my barracuda has.
Re: ´67 Barracuda wiper switch and wiper motor... [Re: Heimo572] #1414423
04/09/13 12:52 AM
04/09/13 12:52 AM
Riverside, California
ghostrider Offline
ghostrider  Offline
The Abodies could have the variable speed wiper setup in 67.
Must remember... my humor doesn't work on forums.....my humor doesn't work on forums. Former Mopars include 69 Super Bee, 71 Sebring, 68 Charger, 69 Charger, 78 D150, 67 300, 71 Road Runner clone, 79 T-top Doba, 67 Barracuda, 91 TC by Maserati, 68 Town & Country
Re: ´67 Barracuda wiper switch and wiper motor... [Re: ghostrider] #1414424
04/09/13 02:19 AM
04/09/13 02:19 AM
Northern Tier
BCSharp Offline
BCSharp  Offline
Northern Tier
I will add this from my own experience. I have a 67 Barracuda with the variable speed motor. The switch has a couple clicks then a rheostat action to it. It had a later 3 speed motor wired in with the original variable speed switch and didn't work right. I obtained an original 67 (only? Can't remember) variable speed motor and it works correctly with the switch. Basically seems you need to ensure your switch/wiring matches the motor your using.
71 Charger R/T 67 Barracuda 99 Ram Sport 09 Challenger R/T
