loses oil presure #1414408
04/04/13 12:54 PM
04/04/13 12:54 PM
IL. Jerseyville
jg309 Offline OP
jg309  Offline OP
IL. Jerseyville
go a freind with a .060 over bore 340,been align bored,lifter busnings,different crank, after engine warms up to operating temp. or 6thru 7 laps it loses oil presure & usualy the mains are junk, we've checked every thing we can think of any suggestion as to whats causing this problim, thanks jg309
Re: loses oil presure [Re: jg309] #1414409
04/04/13 01:08 PM
04/04/13 01:08 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
What is the oil system comprised of? What is your peak rpm? What size track? What are the clearances set to? What other oiling system mids were done? Need a lot more info...
Re: loses oil presure [Re: jg309] #1414410
04/04/13 02:41 PM
04/04/13 02:41 PM
Is the plug in the main oil galley (under the rear main cap, I think ) that routes the oil to the oil filter in place If not, put it in
Re: loses oil presure [Re: Cab_Burge] #1414411
04/04/13 02:48 PM
04/04/13 02:48 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
thats the first thing I would check, its called a diverter plug, like said before, need alot more info on the system and componets.
Re: loses oil presure [Re: dartman366] #1414412
04/04/13 03:14 PM
04/04/13 03:14 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I know we don't like to think good machine shops make mistakes but they do. Ck the size of the lifter bushings, a few thousandths too large and a lot of oil is lost. Ask me how I know!!!
Re: loses oil presure [Re: Blucuda413] #1414413
04/05/13 08:24 AM
04/05/13 08:24 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Check the plug at the rear of the engine on the lifter galley to the left of the distributer drive gear.
Re: loses oil presure [Re: jg309] #1414414
04/05/13 08:36 AM
04/05/13 08:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the oil pressure when you fire it up and what
does it drop to(at like 2000 rpm)
Re: loses oil presure [Re: MR_P_BODY] #1414415
04/06/13 01:11 PM
04/06/13 01:11 PM
Go to www.moparchat.com then scroll down to & click on "circle track chat" then peruse Sanborns SB oiling mods that are in a sticky at the top of the page. (it'll take you awhile). When you're done you'll have your answer
Re: loses oil presure [Re: RapidRobert] #1414416
04/06/13 02:12 PM
04/06/13 02:12 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Yea If I was a small block guy ..that is a must read. A lot of info there ! By A smart guy.
Re: loses oil presure [Re: VernMotor] #1414417
04/06/13 09:21 PM
04/06/13 09:21 PM
IL. Jerseyville
jg309 Offline OP
jg309  Offline OP
IL. Jerseyville
all sanborn oil mods. have been done to this block aswell as hughes oil mods., lifter busnings are in correct we checked, talked to ryan about the problim he said that he had a s/b one time that worked real well & they freshen it & it did the same thing, & it dont it the 2nd & 3rd time they finnaly gave up on it just to costly, thats what we'll probly do,thanks for all the help,it holds 70-75lbs @ idel,80+ till about 6th lap on 3/8 mile track, later jg309,thanks again
Re: loses oil presure [Re: jg309] #1414418
04/16/13 10:31 AM
04/16/13 10:31 AM
IL. Jerseyville
jg309 Offline OP
jg309  Offline OP
IL. Jerseyville
found out what wascausing the problim,it was the oil pump drive gear-shaft,it was a older one that was not pined, & when hot it would slip on shaft with the higher oil pressure,thanks guys,just thought i let everyone know,jg309
Re: loses oil presure [Re: jg309] #1414419
04/16/13 02:13 PM
04/16/13 02:13 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Excellent work
Re: loses oil presure [Re: jg309] #1414420
04/16/13 05:23 PM
04/16/13 05:23 PM
Most problems that occur in racing have solutions, the bad guys give up and the good guys find the problem and correct it, no matter how hard or how difficult
Re: loses oil presure [Re: Cab_Burge] #1414421
04/16/13 09:52 PM
04/16/13 09:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Outstanding find!
