Re: loses oil presure
[Re: jg309]
#1414409
04/04/13 01:08 PM
04/04/13 01:08 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
What is the oil system comprised of? What is your peak rpm? What size track? What are the clearances set to? What other oiling system mids were done? Need a lot more info...
[Re: Cab_Burge]
#1414411
04/04/13 02:48 PM
04/04/13 02:48 PM
dartman366
Mt. Vernon, Ohio
Is the plug in the main oil galley (under the rear main cap, I think ) that routes the oil to the oil filter in place If not, put it in
thats the first thing I would check, its called a diverter plug, like said before, need alot more info on the system and componets.
[Re: jg309]
#1414414
04/05/13 08:36 AM
04/05/13 08:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
go a freind with a .060 over bore 340,been align bored,lifter busnings,different crank, after engine warms up to operating temp. or 6thru 7 laps it loses oil presure & usualy the mains are junk, we've checked every thing we can think of any suggestion as to whats causing this problim, thanks jg309
Whats the oil pressure when you fire it up and what does it drop to(at like 2000 rpm)
[Re: MR_P_BODY]
#1414415
04/06/13 01:11 PM
04/06/13 01:11 PM
RapidRobert
Go to www.moparchat.com then scroll down to & click on "circle track chat" then peruse Sanborns SB oiling mods that are in a sticky at the top of the page. (it'll take you awhile). When you're done you'll have your answer
[Re: RapidRobert]
#1414416
04/06/13 02:12 PM
04/06/13 02:12 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Yea If I was a small block guy ..that is a must read. A lot of info there ! By A smart guy.
[Re: jg309]
#1414420
04/16/13 05:23 PM
04/16/13 05:23 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
found out what wascausing the problim,it was the oil pump drive gear-shaft,it was a older one that was not pined, & when hot it would slip on shaft with the higher oil pressure,thanks guys,just thought i let everyone know,jg309
Most problems that occur in racing have solutions, the bad guys give up and the good guys find the problem and correct it, no matter how hard or how difficult
