Exhaust Cutouts #1414339
04/04/13 06:19 AM
04/04/13 06:19 AM
London, England
JFChallenger440 Offline OP
London, England
Been thinking about getting exhaust cutouts for a while now, after shipping etc here to England it's going to be quite expensive to get the electronic ones so thinking of just getting manual ones, anyone used the manual ones ? I'm a bit concerned about leaks or are they quite good at sealing ? The ones my local parts place has are these, see link, scroll down to S9/14 , also is there any amount of time they should not be opened up for when driving or is it ok to have them open all the time if I wanted ? Thanks
http://www.realsteel.co.uk/section9.pdf
Re: Exhaust Cutouts [Re: JFChallenger440] #1414340
04/04/13 08:28 AM
04/04/13 08:28 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run them on 2 cars.My kid had to replace a cap gasket on his once in about 7 years.Mine have been on for about 8 years still running the OE gaskets.They seal with no problems.I have mine angled towards the outside of the car.Easy to get to the 3 wing nuts to uncap them.I used anti sieze on the threads so they dont rust on.I can uncap mine in a few minutes.Rocky
Chrysler Firepower
Re: Exhaust Cutouts [Re: therocks] #1414341
04/04/13 09:08 AM
04/04/13 09:08 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I use the summit cut-outs. They work great. No issues at all. It takes like 2 minutes a side to uncap them. No need to even jack the car up. I did replace the "wing" nuts w/ standard nuts.
Coming soon!!!!
Re: Exhaust Cutouts [Re: Mr.Yuck] #1414342
04/04/13 11:44 AM
04/04/13 11:44 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I had my local exhaust shop fab some up from scratch. If you do that, it would save you the shipping charges.
They way I had them do it was to go from my 3" header collector to a 3" diameter cutout that angles to the outside of the car. No issues with sealing.
Re: Exhaust Cutouts [Re: 67Satty] #1414343
04/04/13 11:06 PM
04/04/13 11:06 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i just made mine with 2 header collectors welded to a y pipe and made up a cap to match with header collector gaskets and nuts and bolts...easy set up
Re: Exhaust Cutouts [Re: JFChallenger440] #1414344
04/05/13 12:54 AM
04/05/13 12:54 AM
Patrick had a novel idea of using a vacuum operated normally open switch to open em up when you get on it . That'd sure beat manually uncapping them & as soon as you spot the Gendarmes (English cops?) you can back off (or a manual override switch)
Re: Exhaust Cutouts [Re: RapidRobert] #1414345
04/05/13 08:14 AM
04/05/13 08:14 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
RR English cops are called Bobbies.The Gandarmines are French.Rocky
Chrysler Firepower
Re: Exhaust Cutouts [Re: therocks] #1414346
04/05/13 08:37 AM
04/05/13 08:37 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I have bought the QTPs...hopefully with any luck I will have them on before Summer. The Manual ones....those are for guys who hit the track and uncork em...guys like me..I wanna be at a bus stop and flip the switch...and if I see a cop in the distance, close em up. I would also like to wake the dead...as well as the neighbors...If you aren't in a rush I can ask my guys in New York if they ship out directly to the UK. I bring in all my stuff through a cargo ship and its usually quite cheaper than sending it by post and there is less of a chance of it getting stopped at customs. Are you in a car club out there? Perhaps someone knows a broker that can take care of all the paperwork for you. The only other option I can help you out with is if you buy em and have them shipped to New York, I can have them come to my place in Greece (Bit of an overshoot from the UK) but then I can send them through the post from here and being that its within the EU, no customs fees. Just an option.
Maybe hit up this place....place an order with them and their next shipment from the States could include your cutouts and have them ship it to you since they are way closer than me.
http://store.moparshop.de/
Good luck.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Exhaust Cutouts [Re: therocks] #1414347
04/05/13 10:50 AM
04/05/13 10:50 AM
Got it
Re: Exhaust Cutouts [Re: RapidRobert] #1414348
04/05/13 11:19 AM
04/05/13 11:19 AM
London, England
London, England
Pete, many thanks for the offer but my local place has the manual ones in stock so i'll probably just go for them if I get them
Another thing is where is the best place ideally to fit them, currently my Flowmaster exhaust system end just in front of the rear wheels
Re: Exhaust Cutouts [Re: JFChallenger440] #1414349
04/05/13 11:47 AM
04/05/13 11:47 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Put them between the header collector and the H-Pipe/X-Pipe (whichever you have). Or if you don't have an H-Pipe/X-Pipe, put them relateively close to the end of the header collector.
Get them the same diameter of your header collector, then reduce down to the diameter of the rest of your system.
Re: Exhaust Cutouts [Re: RapidRobert] #1414350
04/05/13 05:07 PM
04/05/13 05:07 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
not a great pic,they dont stick out like it looks in the pic.
Re: Exhaust Cutouts [Re: bonefish] #1414351
04/13/13 10:23 AM
04/13/13 10:23 AM
London, England
London, England
Just measured my pipes and they 2.5" OD so what size cutouts will I need to order?
Re: Exhaust Cutouts [Re: JFChallenger440] #1414352
04/13/13 11:23 AM
04/13/13 11:23 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
2.5" QTP's are the way to go. Don't forget to put a short flared end on them. It improves the sound dramatically. I used an oval shaped megaphone end for clearance. It works the same way as the flare on a trumpet or other horn works. It takes the harshness out of it and sweetens it the sound.
Re: Exhaust Cutouts [Re: jbc426] #1414353
04/13/13 02:45 PM
04/13/13 02:45 PM
London, England
London, England
Shouldn't the ones I order though be a slight smaller or larger size than my current pipes in order for them to slot over them ? Is it best to weld them ?
Re: Exhaust Cutouts [Re: JFChallenger440] #1414354
04/14/13 08:36 AM
04/14/13 08:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You probally have to have them flared.I took mine to the Midas shop and had them use their tool thats hydraulic for flaring pipes.Guy didnt even want ant $$$$.I gave him 10 bucks for his trouble.I welded mine on.Rocky
Chrysler Firepower
Re: Exhaust Cutouts [Re: JFChallenger440] #1414355
04/14/13 02:25 PM
04/14/13 02:25 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
It is awesome!!!! I loved having cutouts, I got the cheap one from summit for 30 bucks, put them behind my h pipe
Mike
1969 Dodge Dart Swinger
Re: Exhaust Cutouts [Re: JFChallenger440] #1414356
04/14/13 08:21 PM
04/14/13 08:21 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Not sure what you mean. They bolt on to a header flange. THese are a different brand.
Re: Exhaust Cutouts [Re: JFChallenger440] #1414357
04/14/13 08:53 PM
04/14/13 08:53 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I have manual ones on my Duster and it takes me a minute or two at the track to undo each one, without needing a jack. They've been on the car for years now and have always sealed up great.
Re: Exhaust Cutouts [Re: dustergirl340] #1414358
04/16/13 05:41 AM
04/16/13 05:41 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I just dont get this idea.
Unless... there is a valve right where the pipe splits into full system/cutout (read: to route the FULL exhaust volume to either the cutout OR the mufflers), is the exhaust not just flowing into both pipes even if its uncorked? Whats the point besides just making more noise? On a personal note, I think they sound terrible, unless you wanna sound like a rez-pickup truck. And they have to be hurting power on any GOOD system.
