edel victor oil drain hole blocked #1414244
04/03/13 08:30 PM
04/03/13 08:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
So I am going to taper the hole to divert the oil past the block edge.[kp440]
Re: edel victor oil drain hole blocked [Re: Clanton] #1414245
04/03/13 08:40 PM
04/03/13 08:40 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
2
Re: edel victor oil drain hole blocked [Re: Clanton] #1414246
04/03/13 08:46 PM
04/03/13 08:46 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
3
Re: edel victor oil drain hole blocked [Re: Clanton] #1414247
04/03/13 08:50 PM
04/03/13 08:50 PM
Arizona
Chris'sBarracuda Offline
Arizona
I spoke to an Edelbrock engine builder at The MATS and he said they were making some changes to the Victor Heads, especially the push rod problems..
Chris..
Re: edel victor oil drain hole blocked [Re: Clanton] #1414248
04/03/13 08:57 PM
04/03/13 08:57 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
4.
Re: edel victor oil drain hole blocked [Re: Chris'sBarracuda] #1414249
04/03/13 09:00 PM
04/03/13 09:00 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Chris..
interesting,I wonder what.
Re: edel victor oil drain hole blocked [Re: Clanton] #1414250
04/03/13 09:06 PM
04/03/13 09:06 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I have to do the same to the drain back on my eddy/mopar heads
Re: edel victor oil drain hole blocked [Re: VernMotor] #1414251
04/03/13 09:25 PM
04/03/13 09:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am going to use a die grinder and chanal to the valley where the ink is on the head by the pr hole.
Re: edel victor oil drain hole blocked [Re: Clanton] #1414252
04/03/13 09:39 PM
04/03/13 09:39 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
A better shot of the head,it is marked with ink where the water passages are also and how they lignup on gasket.
Re: edel victor oil drain hole blocked [Re: Clanton] #1414253
04/04/13 08:10 PM
04/04/13 08:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
it will drain now
Re: edel victor oil drain hole blocked [Re: Clanton] #1414254
04/04/13 08:15 PM
04/04/13 08:15 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I also matched the water holes better n opened up the gasket.
Re: edel victor oil drain hole blocked [Re: Clanton] #1414255
04/04/13 08:29 PM
04/04/13 08:29 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
last1
Re: edel victor oil drain hole blocked [Re: Clanton] #1414256
04/04/13 08:38 PM
04/04/13 08:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
it will drain now
What makes you think it will drain any better, being
that those holes are up top
Re: edel victor oil drain hole blocked [Re: MR_P_BODY] #1414257
04/04/13 09:35 PM
04/04/13 09:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
it will drain now
because the drain hole are not blocked any more,ya gotta start somewhere.
Re: edel victor oil drain hole blocked [Re: MR_P_BODY] #1414258
04/04/13 10:06 PM
04/04/13 10:06 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
it will drain now
would you feel better about it if I put the heads on and dumped oil in the head and watched it drain?or what is your point?
Re: edel victor oil drain hole blocked [Re: Clanton] #1414259
04/04/13 10:09 PM
04/04/13 10:09 PM
Arizona
Arizona
it will drain now
Drain lines like B1's..
Chris..
Re: edel victor oil drain hole blocked [Re: Chris'sBarracuda] #1414260
04/04/13 10:30 PM
04/04/13 10:30 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
it will drain now
Chris..
I did not know they needed them!
Re: edel victor oil drain hole blocked [Re: Clanton] #1414261
04/04/13 11:02 PM
04/04/13 11:02 PM
Arizona
Arizona
it will drain now
Chris..
Couldn't hurt.. drain holes look small.. I don't have any experience with these though.
Chris..
Re: edel victor oil drain hole blocked [Re: Chris'sBarracuda] #1414262
04/04/13 11:05 PM
04/04/13 11:05 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I just looked at the heads and I am not worried in the least.
Re: edel victor oil drain hole blocked [Re: Clanton] #1414263
04/04/13 11:09 PM
04/04/13 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
it will drain now
Do what you want to.. doesnt matter
