Re: throttle/kickdown bracket
[Re: 72d100]
#1414140
04/03/13 06:50 PM
04/03/13 06:50 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Trash all of it and go with the Lokar cable system. Its too easy and gets rid of all of that stuff.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: 72d100]
#1414141
04/03/13 07:06 PM
04/03/13 07:06 PM
Posts: 4,925 Wills Point, Texas
Hugh Jorgan
Wills Point, Texas
besides needing the edelebrock adapter what linkage do i need for this
Tough crowd. Good thing you're not asking about your dog...they would be telling you to take it out back and shoot it in the head.
Looks like all you need is the stud that bolts onto the carb linkage. I have the same setup on my truck and it runs fine.
[Re: shortbed88]
#1414149
04/04/13 12:59 AM
04/04/13 12:59 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I would take the factory linkage over the crappy Lokar any day!
I have a Lokar cable in my swap meet bucket I took off my Ramcharger. Not able to locate a factory linkage I went with the BPE throttle plate and factory type cable for the 518 trans swap.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: Hugh Jorgan]
#1414150
04/04/13 09:25 AM
04/04/13 09:25 AM
Posts: 15,487 Florida
scratchnfotraction
[Re: scratchnfotraction]
#1414151
04/04/13 09:27 AM
04/04/13 09:27 AM
scratchnfotraction
here it is on a tall rpm intake. I did riase the throttle cable clamp so the cable was level with the stud since this pic.(and they said stock linkage wont work on the RPM intake...) stock 78-440 truck 3-piece linkage just swaped a 3-piece set up over to the 85 318/727 replacing the 1 piece set up. it is off a mid 80s SB 4-v dippy. much more adjustability with the 3 piece. if you need the tall intake bracket for the B-engine,AREngineering has them.
#1414154
04/04/13 01:28 PM
04/04/13 01:28 PM
Posts: 3,235 Marion Illinois
72d100
Marion Illinois
scratch it looks like we have the same setup, it your throttle cable goig at an angle to the carb. mine might as well be in the back of the carb
#1414155
04/04/13 08:16 PM
04/04/13 08:16 PM
Posts: 5,964 Greenville, PA
redraptor
Greenville, PA
I could never shoot this guy.
RIP Dutch
Dutch looked like a cute guy. Having a throttle bracket from a cruise control vehicle can help with the hi-rise intake.
[Re: shortbed88]
#1414157
04/04/13 09:58 PM
04/04/13 09:58 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
not to hijack this thread but....what type of replacement cable does that factory setup use? I have one for a Dodge van and the thing is about 6 feet long. I need to get this figured out so I can install my a518.
91 Dodge van is what I used when I built my 1st one from scratch The Bouchillion kit uses the same cable it looks like I compared them when I got my 1st Bouchillion
