Page 3 of 3 1 2 3
Re: Rocker arm geometry on a 440 [Re: Jerry] #1414047
04/08/13 11:46 AM
04/08/13 11:46 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
That's what I thought Jerry
Re: Rocker arm geometry on a 440 [Re: 1_WILD_RT] #1414048
04/08/13 12:43 PM
04/08/13 12:43 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I've saved a few pictures from threads about rocker geometry in the past... First the rocker arm length that Andy mentioned... It would be nice it the rocker brands were mentioned ....
Dove / Indy / Racer Brown; Crane Gold; Hughes; Harland Sharp, Crane iron, either Comp Pro Magnum or C.A.T. ripoffs of same.
Re: Rocker arm geometry on a 440 [Re: BradH] #1414049
04/08/13 02:53 PM
04/08/13 02:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The harland sharps should work fine on stock heads - they're an ancient design from when there were no aftermarket heads. The geometry isn't that great on stuff like Indy's, etc.
Re: Rocker arm geometry on a 440 [Re: BradH] #1414050
04/09/13 12:25 AM
04/09/13 12:25 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And from that we get... BTW Thank You..
Re: Rocker arm geometry on a 440 [Re: AAR-B4] #1414051
06/08/13 08:55 PM
06/08/13 08:55 PM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
What will you gain by centering the roller contact?
You have added the roller, that will greatly reduce the side-load on the valve stem and save the guide.
Put it together, race it and have fun.
I agree, especially given the extra large roller on the HS rockers.
I just ran into the exact same issue with my HS rockers on my Edelbrock heads, although mine seem to be slightly closer to center
But even if you went with lash caps, the recessed valve locks and lash caps would run about $80 plus pushrods, which is a lot less than a new set of good rockers.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: Rocker arm geometry on a 440 [Re: 1KoolBee] #1414052
06/09/13 06:34 PM
06/09/13 06:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
In general, I agree that if the scrub path is small and a safe distance away from the stem tip's edge I'd leave it alone.
The roller diameter is a bit of a design puzzle. Most mfg. have settled on a 3/8" OD roller as a reasonable compromise between 2 extremes:
1. A really small roller (like 1/4") punishes the stem tip, and has very few needle bearings actually loaded = early failure. Only a few needles at the top of the roller take the entire load, and they don't actually rotate - they oscillate a few degrees.
2. A really big roller (like 1/2") lives longer, loads many more needles, and locally depresses the stem less in psi (yes, I know in theory it's only line contact!), but that's the worst possible place to add both weight and inertial resistance - the roller must reverse rotation instantly or it scuffs across the stem.
Roller tips effectively increase the stem height (compared to pallet ends, as far as geometry is concerned) by their radius, since the axle is the "end" of the stem.
When you run a big roller, the rocker doesn't change (as to geo), but now the valve is too long.
Warren Johnson played with geo on his "stock" Olds 350 motors 100 years ago.
Boffin Emeritus
Re: Rocker arm geometry on a 440 [Re: polyspheric] #1414053
06/09/13 11:38 PM
06/09/13 11:38 PM
Minneapolis, MN
moparguy Offline OP
moparguy  Offline OP
Minneapolis, MN
after talking with you guys, and also with Harland Sharp, I put it together and ran it. works perfectly so far.
Page 3 of 3 1 2 3
