replace spark plugs on GM 3.1 HELP! #141403
10/25/08 07:11 PM
10/25/08 07:11 PM
Pittsburgh, PA
roadrunnerh Offline OP
Pittsburgh, PA
Ok folks, I know it's a brand X...but I have to change the plugs and wires on my wife's '98 Olds Achieva 3.1 V6. The rear plugs seem real difficult to get to. Any suggestions would be greatly appreciated!
Harry
1968 Road Runner
1975 Scamp
Re: replace spark plugs on GM 3.1 HELP! [Re: roadrunnerh] #141404
10/25/08 07:21 PM
10/25/08 07:21 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Some of those cars, luminas and such, the dog bones can be loosened and engine tipped forward. Don't know about the achieva.
Re: replace spark plugs on GM 3.1 HELP! [Re: roadrunnerh] #141405
10/26/08 03:53 PM
10/26/08 03:53 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I'll tell you how I did my wife's Gran Am GT..Spark plug socket and two long extensions...You're not going to see what you're doing so don't even try...It's all feel...but I did use a small mirror on the telescopic handle just to look in there between the plugs going in and out...Another piece of advice is to spin the plug almost out then back in until finally spining it free...Those aluminum threads are unforgiving with even a small amout of dirt/carbon...I started to take the original set straight out and one of the holes in the back would'nt take the new plug... ...I had to buy a thread chaser... Then finished the rest making sure to clean the threads on the way out...
Re: replace spark plugs on GM 3.1 HELP! [Re: buildanother] #141406
10/26/08 04:04 PM
10/26/08 04:04 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Probably have to remove the upper dog bone mount and tilted the motor forward and that should give you room to get to the back side plugs.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: replace spark plugs on GM 3.1 HELP! [Re: moparmarks] #141407
10/26/08 04:56 PM
10/26/08 04:56 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Your'e just lucky its not a montana or venture.....
Re: replace spark plugs on GM 3.1 HELP! [Re: roadrunnerh] #141408
10/26/08 05:45 PM
10/26/08 05:45 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
I just did them on a '99 Grand Am with the 3.4. You have my sympathy.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: replace spark plugs on GM 3.1 HELP! [Re: RemCharger] #141409
10/26/08 07:50 PM
10/26/08 07:50 PM
moparmarks Offline
moparmarks  Offline
Or a newer Ford truck.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: replace spark plugs on GM 3.1 HELP! [Re: moparmarks] #141410
10/26/08 08:03 PM
10/26/08 08:03 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
gm has a tool that replaces the dog bone mount and pulls the engine forward..other than that...wear long sleeves....look forward to cuts and black and blues...
Re: replace spark plugs on GM 3.1 HELP! [Re: 67Charger] #141411
10/26/08 08:11 PM
10/26/08 08:11 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Isn't the 3.4 a dohc? That's the one the upper intake needs to come off and just get one for a alt. On the 3.1 as stated remove the ft dog bone mount(just remoce the bolt on one side) and get someone in the car to jam the parking brake as you rock the car back while still in park. The motor will roll foward and the plugs are much easier to get.
Re: replace spark plugs on GM 3.1 HELP! [Re: roadrunnerh] #141412
10/26/08 08:18 PM
10/26/08 08:18 PM
IMGTX Offline
IMGTX  Offline
I found that on my brothers car I could get to the right rear ones through the holes in the inner fender behind the passenger tire.
I took the tire off and was able to get to it easier.
The other two were either from the bottom or after I took the coil pack off. It's been awhile but at least you don't have to change them often.
Re: replace spark plugs on GM 3.1 HELP! [Re: moparmarks] #141413
10/26/08 08:28 PM
10/26/08 08:28 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I can do either of them in an hour. Of course thats what I do all day every day. Get the coil packs out of the way and its easy.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: replace spark plugs on GM 3.1 HELP! [Re: 70dart360] #141414
10/26/08 10:59 PM
10/26/08 10:59 PM
Pittsburgh, PA
Pittsburgh, PA
Mission accomplished.
Geeze, what a PITA. The dogbone was on the right side (pass. side) which is the front of the motor. I removed the three bolts and using a floor jack and a piece of wood, I jacked the rear of the motor (actually side of motor) and it tilted enough forward. It gave me eoungh room - barely. 2 1/2 hours for me, start to finish. My wife was wondering why I kept putting it off. Now she knows. Thanks everyone for the information!
My Real car is a '68 Road Runner. My daily driver is a '98 neon - which is very easy to work on!
Harry
1968 Road Runner
1975 Scamp
Re: replace spark plugs on GM 3.1 HELP! [Re: roadrunnerh] #141415
10/26/08 11:52 PM
10/26/08 11:52 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Any 90's transverse V6 Chrysler, 92 Diamante where the intake goes back over the rear bank, or a 93 LS400 where the plugs are under a cover that are clipped under 3 other layers of covers. Its like a puzzle. Of course B/RB's with logs in a narrow A engine bay is no fun either.
