Installing New Mark Williams Yoke on a Dana 60 #1413766
04/02/13 05:19 PM
04/02/13 05:19 PM
Chicago,Illinois
N
nosboy Offline OP
nosboy  Offline OP
N
Chicago,Illinois
Bought a new mark WIlliams Yoke for my Dana 60 and I was wondering HOW to replace it.. Do I need to install a shim or something to re crush the sleeve?? Or do I need a new sleeve??? How tight do I torque the nut..???.. PLEASE HELP.... Dana 60, 4.56 Auburn Gear, Strange Spool and Strange 35 spline axles.. Thank You in advance.. Gary Oles Nosboy
Re: Installing New Mark Williams Yoke on a Dana 60 [Re: nosboy] #1413767
04/02/13 05:26 PM
04/02/13 05:26 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
i think most dana 60's have shims not a crush sleeve, just make it tight 100 ft lbs?
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Installing New Mark Williams Yoke on a Dana 60 [Re: nosboy] #1413768
04/02/13 05:38 PM
04/02/13 05:38 PM
PA
Z
zooom Offline
zooom  Offline
Z
PA
Most, if not all Dana 60's didn't use a crush sleeve to establish pinion bearing preload. They used shims.
Best way to remove/replace the companion flange without disturbing preload is to disconnect driveshaft, remove both rear wheels & brake drums/calipers & turn the companion flange with an inch/pound torque wrench to determine the rotating torque. Record this number. Next remove the pinion nut, belleville washer & pull off the old companion flange using the appropriate tools. Lubricate the new MW companion flange & install it on the pinion gear along with a new belleville washer & new pinion nut. Torque the nut down until you reach the same +/- rotating torque that you recorded from the original setup. In most cases you will need to tighten the nut to at least 250 foot/pounds or more to reach the desired rotating torque and not result in a differential assembly with a "loose" pinion nut....
Those of us with many years of experience setting up gears [correctly!] often use our hands to determine the rotating torque from the initial assembly. Newbys & novices should use measuring tools for best results...
When you're satisfied with the rotating torque value & you've reached at least the 250 ft/lb tightening number, you can reassemble the differential & road test!
Re: Installing New Mark Williams Yoke on a Dana 60 [Re: zooom] #1413769
04/02/13 11:15 PM
04/02/13 11:15 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
Re: Installing New Mark Williams Yoke on a Dana 60 [Re: loaderpro] #1413770
04/03/13 12:36 AM
04/03/13 12:36 AM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
Is this the OEM style yoke or the dragster/coupler one?
Re: Installing New Mark Williams Yoke on a Dana 60 [Re: nosboy] #1413771
04/03/13 03:43 AM
04/03/13 03:43 AM
Don't worry about overtightenting a Dana 60 pinion nut in the car unless you have a 3/4 inch or one inch impact air wrench with a very big air compressor As already said some of the FSM show using 250 Ft lbs on them, others show 150 Ft Lbs. I use a 3/4 inch drive breaker bar with a 8 ft. long cheater extension on it and then jump up and down(220 lbs weight)it until it quits getting tighter(that is with the rear end out of the car on the shop floor I am one of the low experienced rear end guys so I use the FSM procedure to check the pinion bearing preload as well as pointing the pinion straight up into the air when checking the rotational torque both ways with a 1/4 drive inch pound beam type torque wrench Once you get it within factory specs . you have to remove the pinion nut and yoke to install the pinion bearing seal BTW, I have a stock of non lock nut pinion nuts(grade 8 extra long ) so I don't use the lock nuts that come with new gears
