Re: MSD EFI Fuel System
[Re: dnd0001]
#1413664
04/02/13 03:20 PM
04/02/13 03:20 PM
Posts: 4,848 Memphis
HemiRick
Memphis
This is a throttle body EFI and still has many drawbacks of a carb. OEM's quit using throttle bodies years ago for good reason, port fuel injection is MUCH better. If you're going to spend the money on EFI, you really want port injection. Yes it does cost a little more because you need a special intake manifold and 8 injectors....but then you have all the benefits of EFI not just half of them.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: dnd0001]
#1413669
04/02/13 04:50 PM
04/02/13 04:50 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I believe you biggest issue is the return line size. Common sense says otherwise, but the 1/4" vapor line inhibits proper operation of the regulator, causing intermittent problems. If motor is mild, it might better to use 1/4" as supply, up the pressure a bit.
Any EFI's guru's concur?
are just add another 3/8" and forget about it.
[Re: fuseable]
#1413674
04/03/13 11:28 AM
04/03/13 11:28 AM
Posts: 1,377 Ohio
Todd
Ohio
[Re: Todd]
#1413675
04/03/13 03:35 PM
04/03/13 03:35 PM
Posts: 4,872 connecticut
pnypwr
connecticut
Keep in mind if you put the pump in the tank you will need to baffle it or run an external reservoir. The pump will pull air causing a lean condition on low fuel levels around corners. Also you will need a bigger return line usually the same size as feed line.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#1413676
04/03/13 05:52 PM
04/03/13 05:52 PM
Posts: 8,881 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Huh ?!?!? What good does that do if the pump pulls air?
[Re: jbc426]
#1413678
04/03/13 07:46 PM
04/03/13 07:46 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I used these guys ( http://www.radiumauto.com/ ) surge tank. They make nice stuff.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
