Piston oil squirters on big block
#1413223
04/01/13 06:13 PM
04/01/13 06:13 PM
Posts: 1,417 Chicago, IL
blownEFI
Chicago, IL
I am interested to hear from people who have used piston oil squirters on a big block Mopar and how well it worked for them. Did you use check-valve type squirters or just simple jet? What size orifice? Did it help with piston cooling?
I have a Keith Black 541 and my builder has installed 0.031 squirters (non-check-valve). We have run it in on the dyno and there were no problems with oil pressure. We're hoping the oil jets will help with piston temps, this is a turbo application.
"These go to eleven", Nigel Tufnel
Re: Piston oil squirters on big block
[Re: ahy]
#1413226
04/03/13 07:31 AM
04/03/13 07:31 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
.031" sounds like a lot. Have you experienced problems with piston temperatures, or why are you doing it?
Plynouth VIP '67 TT IC EFI
