My wife's '03 Caravan has had noise in the front end for a while. Today I checked it out and it looks like the inner tie rod ends are worn (clunks when rocking the steering wheel back and forth)
One place I called wants $500-plus for inner/outer tie rod ends and alignment.
But looking on Rock Auto, I can get a rebuilt rack (AC Delco) and outer tie rod ends (Moog) for under $400. And if I replace the rack, I'll fix a small leak and the worn tie rod problem at the same time.
So, has anyone replaced a rack on a Caravan? If so, how hard is it? I have a Haynes manual but that thing is practically worthless for information. A typical task tells you to remove Widget A, but doesn't mention that there's about ten things you have to do to actually remove it.....
And when a rebuilt rack is called "complete", does it come with inner tie rod ends? That's what the picture shows, but I want to be sure.....
