440/383 Flywheel Question
#141283
10/25/08 12:19 PM
10/25/08 12:19 PM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
I have a 1970 440 motor that I want to install in my 1968 383 4spd Super Bee. I want to use the 11inch flywheel from the orig 383. My interchange manual says the 1970 440's used a 10.95 in flywheel thats not interchangable with the 11in 68. I tried that anyway and all the bolts line up and appears to fit fine bolt pattern wise. It appears to be very snug at the crank alignment hole as the flywheel pulls in tightening the bolts. I also double checked the bell housing and it is fine also. My question is does the 1970 flywheel have a different bolt pattern? Or could there be balance issues if I use the 11? This 1970 motor was assembled on 9/5/69. Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 440/383 Flywheel Question
[Re: RTDaddy]
#141286
10/25/08 09:39 PM
10/25/08 09:39 PM
TimS
Walton, Indiana
Thanks for the info. I didn't want to order my clutch setup until I verified I could interchange. My plan is to rebuild the #'s 383 and use the 440 until I am done with that. The only thing I noticed was that the flywheel center hole was really snug. I could get the bolts on fine but it wouldn't tighten all the way up. I may have to buff one or the other to get it to slide on the crank a little easier. Should I have to smack that flywheel with much force to get it on? I wouldn't think so.
