440/383 Flywheel Question #141283
10/25/08 12:19 PM
10/25/08 12:19 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I have a 1970 440 motor that I want to install in my 1968 383 4spd Super Bee. I want to use the 11inch flywheel from the orig 383. My interchange manual says the 1970 440's used a 10.95 in flywheel thats not interchangable with the 11in 68. I tried that anyway and all the bolts line up and appears to fit fine bolt pattern wise. It appears to be very snug at the crank alignment hole as the flywheel pulls in tightening the bolts. I also double checked the bell housing and it is fine also. My question is does the 1970 flywheel have a different bolt pattern? Or could there be balance issues if I use the 11? This 1970 motor was assembled on 9/5/69. Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 440/383 Flywheel Question [Re: TimS] #141284
10/25/08 01:23 PM
10/25/08 01:23 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
The flywheels will interchange. The difference is the 11" flywheel has a 144 tooth ring gear, the 10.95" one has 130. This requires different bellhousings, casting #2892262 for 69-earier B-body 383/440, and #2892513 for 70-up B/E -body 383-440. With your B-body, either should not be a problem, but on an E, the 11" will get close onthe floor hump. Hope this helps.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: 440/383 Flywheel Question [Re: TimS] #141285
10/25/08 03:11 PM
10/25/08 03:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the '70 440 motor is HP it is externally balanced, the '68 flywheel will need to be modified as per the top figure (13-11) below.
Re: 440/383 Flywheel Question [Re: RTDaddy] #141286
10/25/08 09:39 PM
10/25/08 09:39 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks for the info. I didn't want to order my clutch setup until I verified I could interchange. My plan is to rebuild the #'s 383 and use the 440 until I am done with that. The only thing I noticed was that the flywheel center hole was really snug. I could get the bolts on fine but it wouldn't tighten all the way up. I may have to buff one or the other to get it to slide on the crank a little easier. Should I have to smack that flywheel with much force to get it on? I wouldn't think so.
Re: 440/383 Flywheel Question [Re: TimS] #141287
10/26/08 09:58 PM
10/26/08 09:58 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
clean the flywheel hole and the crank flange by hand with a scotch brite pad and make sure there are no burrs on either as the flywheel should just fall right on .
