Big block power brake booster question. #1412579
03/31/13 11:14 PM
03/31/13 11:14 PM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
I know I need the smaller diameter booster.
If I order one for a 78 with a 440, it will bolt on, right?
Just making sure. I have power brakes now on the 84.
Thanks in advance!
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Big block power brake booster question. [Re: old_goat] #1412580
04/01/13 12:34 AM
04/01/13 12:34 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Just order a 3/4 ton one for your year truck. I've yet to see a 3/4ton with a big booster.
Re: Big block power brake booster question. [Re: 76dodgeboy] #1412581
04/01/13 12:37 AM
04/01/13 12:37 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
They also came on slant six shortbox 2wds. The 440 is the only bigblock that Has to have the small booster do to the deck height. 383/400 clear the big booster just fine
Re: Big block power brake booster question. [Re: 76dodgeboy] #1412582
04/01/13 12:54 AM
04/01/13 12:54 AM
Amarillo, Tx
old_goat Offline OP
Six Abuser
old_goat  Offline OP
Six Abuser
Amarillo, Tx
Thanks!
Mine has the big diameter booster. Is a slant six short box.
84 D150 440/727
79 /6 swb D150
Re: Big block power brake booster question. [Re: old_goat] #1412583
04/01/13 04:18 AM
04/01/13 04:18 AM
Winnipeg, Manitoba, Canada
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
I used one from a 1 ton on my stepside (440 engine) and all I know is my truck stops on a dime with that booster and 11 x 2 1/2 rear drum brakes.
Re: Big block power brake booster question. [Re: 76dodgeboy] #1412584
04/01/13 11:49 AM
04/01/13 11:49 AM
scratchnfotraction Offline
this way the brake pedel hooks up with the clip style brake rod.
the 78 booster will have the shoulder bolt hooking to the pedel.
you can also go to manual brakes for clearance at the VC on the 440,in case you want tall fabricated VC.
here is mine.
