Hellwig vs others for bang for $ rear sway bar?
#1412448
03/31/13 09:27 PM
03/31/13 09:27 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I've been shopping around for a rear bar to add to my wagon. I found this overview thread (for A/E bodies mostly but still useful): https://board.moparts.org/ubbthreads/show...rue#Post5695941I came away liking Hellwig's mounting setup (one hole per side) and the price vs features ($220-ish for non-janky installation plus adjustability). However most folks seem to be running FFs or Addcos. Any experience using these bars on B-bodies or in general?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Hellwig vs others for bang for $ rear sway bar?
[Re: Secret Chimp]
#1412454
04/01/13 01:26 AM
04/01/13 01:26 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I've got the Helwig front & rear bars, not as polished as the Hotchkis stuff but functionally very similar... I wasn't thrilled with the silver veined powder coat (to bright) so I stripped them & powder coated them black... Should have them installed before my first long drive of the Spring....
[Re: 1_WILD_RT]
#1412455
04/10/13 05:11 PM
04/10/13 05:11 PM
Secret Chimp
Eugene, Oregon
Finally got the bar in. I made the mistake of starting just with step drills on hand - har har, you are not going to fit a drill inside of the frame rails if you have your mufflers hung ahead of your axle. Make sure you have a 15/32nds standard bit too so you can do everything from the outside.
Getting the inside and outside holes aligned was pretty easy - if you drill the first smaller hole and then slip a transfer punch into the support sleeve with the sleeve square against the frame rail, you'll be spot on for the inside hole. Getting the holes right for the endlinks is the trickiest part - everything else is pretty much bolt-n-go.
I've driven it through a fair number of different corners so far (all in the rain so far, and my 215 Coopers don't hold on too hard in the wet) and it makes a huuuge difference. I don't know how much the car rolls at higher speeds in the dry, but it stays absolutely modern-car flat with the way I've driven it so far in the wet. It tracks a bit easier down the road.
It really makes the car beg for a better steering box now, too. I've taken a couple of turns leaning in and hanging onto the wheel like I'm in the Indy 500 when it was still a dirt track and... yeah, this big thing needs a bit more heft in the tiller now.
I'll have to see what the car feels like it needs in terms of a front bar, but for my big butt wagon, the stock front bar may be just the right balance. I'm still aiming to get some exterior videos whenever it decides to stay dry for more than an hour here! Overall, easy install and a great buy.
[Re: astjp2]
#1412458
05/02/13 11:12 PM
05/02/13 11:12 PM
Secret Chimp
Eugene, Oregon
Very belated, but here's a quick video. Doesn't look like much but you try making a 120 degree turn in your stock-suspended car at 30 mph and see what happens! Big difference. http://www.youtube.com/watch?v=viTL-r6kigk&feature=youtu.be
[Re: Secret Chimp]
#1412459
05/03/13 12:00 PM
05/03/13 12:00 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I tried to avoid a couch that had fallen out of a truck at 35 mph with my stock suspension and I almost messed myself. I know first hand what you mean.
