cleaning firewall #1412425
03/31/13 08:36 PM
03/31/13 08:36 PM
indiana
moparbrown14 Offline OP
indiana
Got a 74 Duster and trying to clean up and eliminate all the uglyness of it all. There is a wire that comes from the firewall that is about 4 inches above the master cylinder. It has a rubber cone type deal coming from the firewall. Where does it go and what is it for? The inside of it goes to a cluster of wires i cant trace, help?
Re: cleaning firewall [Re: moparbrown14] #1412426
04/10/13 12:48 AM
04/10/13 12:48 AM
New York, USA
Chargerfan68 Offline
New York, USA
On the earlier cars, some had a grey wire similar in description that was for the tach. If it is grey, that could be a possibility...just a guess.
good luck.
