Where to find reproduction fuel filler tubes #1412289
03/31/13 04:37 PM
03/31/13 04:37 PM
Dallas, TX
71_Demon Offline OP
71_Demon  Offline OP
Dallas, TX
Redoing the fuel system on the Demon for contamination. Notice the filler neck is very rusted and could be the cause for my problem.
I have had no luck locating a new one. does anyone know if and where I can find these?
Thanks Kevin
'71 Demon 383 auto '12 Ram 2500 6.7 Diesel
Re: Where to find reproduction fuel filler tubes [Re: 71_Demon] #1412290
03/31/13 11:03 PM
03/31/13 11:03 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I do not think it is repoped , check with B/E+A though.
Re: Where to find reproduction fuel filler tubes [Re: JohnRR] #1412291
04/01/13 10:46 AM
04/01/13 10:46 AM
Dallas, TX
71_Demon Offline OP
71_Demon  Offline OP
Dallas, TX
Thanks Ill check there.
Re: Where to find reproduction fuel filler tubes [Re: 71_Demon] #1412292
04/01/13 11:30 AM
04/01/13 11:30 AM
BDW Offline
BDW  Offline
Any way to resurface them? Maybe something like a POR-15 that is gas resistant?
I have a rusty 1 I'd like to keep also.
Re: Where to find reproduction fuel filler tubes [Re: BDW] #1412293
04/01/13 04:49 PM
04/01/13 04:49 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Wilson Reproductions can replate them. Heres a link to an older thread. Nobody reproduces them that I know of.
https://board.moparts.org/ubbthreads/show...t=1#Post6686478
Re: Where to find reproduction fuel filler tubes [Re: NV69B7RR] #1412294
04/03/13 08:04 PM
04/03/13 08:04 PM
Dallas, TX
71_Demon Offline OP
71_Demon  Offline OP
Dallas, TX
Awesome thank you!
Re: Where to find reproduction fuel filler tubes [Re: 71_Demon] #1412295
04/03/13 09:07 PM
04/03/13 09:07 PM
IN
ahy Offline
ahy  Offline
IN
A "re-surface" option is the 3 step Eastwood gas tank treatment kit. You would have to cap the tube ends to use it but no biggie. The kit uses strong detergent and acetone for cleaning. Muriatic acid to clean/etch and a tough sealer. With the prep steps the sealer seems to hold up well and would eliminate any contamination.
