Changing Oil Brand/Weight on 416" ? #1412132
03/31/13 02:21 PM
03/31/13 02:21 PM
USA
K
krw71ragtop Offline OP
K
USA
I've been using Brad Penn 20W50 partial synthetic oil. I want to switch to Valvoline ZR1 10W30 racing oil. Will there be a problem with this change since the Brad Penn oil is partial synthetic ?
Re: Changing Oil Brand/Weight on 416" ? [Re: krw71ragtop] #1412133
03/31/13 02:39 PM
03/31/13 02:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Shouldn`t be.................
Re: Changing Oil Brand/Weight on 416" ? [Re: Thumperdart] #1412134
03/31/13 02:47 PM
03/31/13 02:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Why are you changing brands? I changed from VR1 20-50 to Brad Penn 20-50 and then switched to Brad Penn 10-30. I went from VR1 to Brad Penn for the higher zinc content as I run a solid cam. Our local speed shop charges 60 dollars per case for Brad Penn.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Changing Oil Brand/Weight on 416" ? [Re: pittsburghracer] #1412135
03/31/13 03:11 PM
03/31/13 03:11 PM
USA
K
K
USA
I have too much oil presure and was hoping the thinner oil would bring it down some. Ya I'm too lazy to drop the pan, steering link, pull right motor mount, and oil pump. The VR1 was $77 a case and Brad Penn is $88 per case ! I was just concerned about the partial synthetic thing in the BP oil compared to non synthetic in the ZR1, and if the Valvoline has enough zinc ?
Re: Changing Oil Brand/Weight on 416" ? [Re: krw71ragtop] #1412136
03/31/13 04:00 PM
03/31/13 04:00 PM
All multi weight oils have some synthetic polymers in them Full synthetic lubricants have no petroleunm based crude stock in them Both work very well I have used Valvoline 5W20Wt in all of my HP stree motors for the last six years, all above 500 HP on Oregon pump swill. I use the same oil in the race motors also with race gas, 700 + HP and torque
Re: Changing Oil Brand/Weight on 416" ? [Re: Cab_Burge] #1412137
03/31/13 04:25 PM
03/31/13 04:25 PM
USA
K
K
USA
Thanks Just wanted to double check with the experienced guys here on moparts.
Re: Changing Oil Brand/Weight on 416" ? [Re: krw71ragtop] #1412138
03/31/13 05:02 PM
03/31/13 05:02 PM
PA.
"Little"John
"Little"John
PA.
Like I said I get a good price local but check this out. Many offer free shipping also.
http://www.amazon.com/s/ref=nb_sb_ss_i_0...nn+%2Caps%2C258
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
