adding cruise control #1411917
03/31/13 03:14 AM
03/31/13 03:14 AM
US
BBD150 Offline OP
BBD150  Offline OP
US
has anyone added cruise control to a 87 and older non cruise control truck? the 87 i built had it all stock. but my 86 doesnt. other then the vacuum assembly under the hood for the carb what else is there? ive been looking for a diagram for wiring. from what ive found it looks like its just the vacuum assembly with a plug in the back for the switch. but im not sure what year the assembly im looking at is. id like to add it without changing a column. possibly run it through a toggle or a push button.
Re: adding cruise control [Re: BBD150] #1411918
03/31/13 12:39 PM
03/31/13 12:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
the cruise switch is part of the trun signal lever on the older vehicles so you don't change the column just the switch arm.
Re: adding cruise control [Re: stumpy] #1411919
03/31/13 12:50 PM
03/31/13 12:50 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Not to highjack your post, but.
My truck came with CC. I'd like to get it working again. What are some of the first things to look at to see why it isn't working? Eveything's there, still hooked up.
Re: adding cruise control [Re: bigblock340power] #1411920
03/31/13 01:44 PM
03/31/13 01:44 PM
US
BBD150 Offline OP
BBD150  Offline OP
US
what year is your truck? and can i get some pictures of the cruise control under the hood?
Re: adding cruise control [Re: BBD150] #1411921
03/31/13 11:06 PM
03/31/13 11:06 PM
Elk Grove, Calif.
Elk Grove, Calif.
Sure, I'll take some tomorrow and post them up. It's a '76 360/auto.
Mike
Re: adding cruise control [Re: bigblock340power] #1411922
04/02/13 02:42 AM
04/02/13 02:42 AM
US
BBD150 Offline OP
BBD150  Offline OP
US
Mike
i cant imagine the cruise control system from back then would be too complicated. i wish the 75 close by had it so i could look at it in person. i cant find anything on google or any pictures. i dont even think the parts stores carry anything for them. im going to go in and check tomorrow. id have to think with a test light you should be able to see if the switch has any power to it. the diaphragm might be bad though and im not sure how to check that.
Re: adding cruise control [Re: BBD150] #1411923
04/02/13 03:12 PM
04/02/13 03:12 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
You have the vacuum pod brain under the hood with the speedo in and out hooks to the throttle with a cable.
Then you have the switches on the turn signal and power up with a brake light switch interrupt .
All plugs into the unit under the hood, if the power is getting to the unit should work, wiring can be found in any vintage 70's wiring diagram.
Not hard to add if you have the parts, going to try it on my 57 Willy's with the 4bt diesel, just need a working vacuum pump
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: adding cruise control [Re: moparts] #1411924
04/02/13 03:15 PM
04/02/13 03:15 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Found this with a quick Google search
Tom ,
2009 Challenger R/T
Re: adding cruise control [Re: moparts] #1411925
04/02/13 04:29 PM
04/02/13 04:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Most of the time I've found the transducer (unit on the fender) to be the problem. Also be sure you have plenty of vacuum.
Re: adding cruise control [Re: stumpy] #1411926
04/02/13 04:47 PM
04/02/13 04:47 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
...also good to have a separate vac-storage-canister.
