Pipe Plug Stuck in 440 Pickup Tube Hole #1411561
03/30/13 06:21 PM
03/30/13 06:21 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
440 engine was in a chassis car last year with external oiling, putting it in my Duster for this year with standard pan and pickup. Went to remove the pipe plug and found it was real tight. Put a good 5/16 hex bit into it and tugged hard with an 18" breaker bar, hex socket stripped out.
Motor is all together and I'm thinking of ways to get this plug out. Maybe stuff the insides with rags and drill it out?
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: cgall] #1411562
03/30/13 06:38 PM
03/30/13 06:38 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
well if you would not of mess up the hex.. I would of try some heat. is any of it sticking out ? if there is you could weld a nut on it. If not drill a hole that you could put a easy-out in. and heat it. heat first then put easy-out in. Good thing is that passage only go to the pump and with it off you clean it out.Is it for a 1/2" pickup or 3/8 ? If 1/2 need to be careful it gets thin on the block.
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: cgall] #1411563
03/30/13 06:41 PM
03/30/13 06:41 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
If there is enough of the plug threads showing you might take a small chisel and hammer and try to back it out. If not maybe grease a drill bit and use nipple extractor or ease out.
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: VernMotor] #1411564
03/30/13 06:42 PM
03/30/13 06:42 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
Vern, motor is all together and has residual oil everywhere, heat or welding might not work well...
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: cgall] #1411565
03/30/13 06:44 PM
03/30/13 06:44 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
Weld a bolt on?
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: cgall] #1411566
03/30/13 06:45 PM
03/30/13 06:45 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
It is a 1/2" pickup, hammer and chisel might be worth a try unless the blocks are known to crack in this area.
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: cgall] #1411567
03/30/13 06:56 PM
03/30/13 06:56 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
O heck all it will do is smoke a little ! make a little tin shield to go around that area.
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: gregsrt] #1411568
03/30/13 06:56 PM
03/30/13 06:56 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That's a short passage in the block if I remember right. Take the pump off. Stuff passage with rags and drill it pretty big then start grinding it out with a drimmel tool and carbide burr. If its that tight an ez out will just break. I like to grind it pretty thin then fold it in with a punch. Just tape off the crank and rods.
Good luck!
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: FastmOp] #1411569
03/30/13 07:08 PM
03/30/13 07:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Being that the short block is already assembled no matter what method you use its going to need a real good cleaning and maybe even taken apart. It may be a good time to buy and use a static pick-up in the oil pan. just a thought.http://store.440source.com/Oil-Pickups/products/59/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: pittsburghracer] #1411570
03/30/13 07:12 PM
03/30/13 07:12 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: pittsburghracer] #1411571
03/30/13 08:51 PM
03/30/13 08:51 PM
SW Ohio
cgall Offline OP
cgall  Offline OP
SW Ohio
Thanks for the tips, guys. Pitts, I like that static pickup
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: cgall] #1411572
03/30/13 09:47 PM
03/30/13 09:47 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
weld a bolt, like mentioned. the heat from the welder helps too
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: mcat4321] #1411573
03/30/13 10:07 PM
03/30/13 10:07 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Plug weld a 1/2" nut to the plug and the heat from the welding will free it up in a jiffy
Gus
64 Plymouth Savoy
Dana 60
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: fourgearsavoy] #1411574
03/31/13 11:33 AM
03/31/13 11:33 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Drive a slightly oversize Torx bit into hex, heat with propane torch and remove. If that does not work, weld a nut on.
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: Lee446] #1411575
03/31/13 11:51 PM
03/31/13 11:51 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I would try the hammer and chiesel method you may end up wit ha broken boss. the plug was probably put in with some type of thread locker , red or even worse the green stuff ,it's going to require heat to break the bond.
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: JohnRR] #1411576
04/01/13 02:16 AM
04/01/13 02:16 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Is the plug cast or steel? if cast that welding trick probably won't work
Re: Pipe Plug Stuck in 440 Pickup Tube Hole [Re: rowin4] #1411577
04/01/13 02:27 AM
04/01/13 02:27 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
If it was installed with loctite, you can spay some good carb cleaner on it a few times through out the day, and usually it will let go. I had this happen to me a few times. It won't work good unless it has a chance to obsorb.
