Clevite "P" bearings. have a Q #141140
10/24/08 10:36 PM
10/24/08 10:36 PM
RapidRobert Offline OP
The Summitt description talks about high eccentricity & greater crush. Is there any longevity problem using these in a low rpm daily driver? These are full groove 400 BB main bearings going onto a turned down 440 crank. thank you for your time.
Re: Clevite "P" bearings. have a Q [Re: RapidRobert] #141141
10/24/08 10:58 PM
10/24/08 10:58 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
they should work fine. in fact all factory rod bearings were "p" bearings. the extra crush holds the bearing in place and the extra excentricity helps the bearing clearances under extreme load, (this is more of an issue with rod bearings). "p" bearings are tri-metal and don't have a lot of embediability so keep the oil changed.
Re: Clevite "P" bearings. have a Q [Re: lewtot184] #141142
10/24/08 11:17 PM
10/24/08 11:17 PM
thanks bro
