small bolt pattern to big bolt pattern change over year #1411120
03/30/13 02:21 AM
03/30/13 02:21 AM
Edmonton AB, CAN
moparz Offline OP
moparz  Offline OP
Edmonton AB, CAN
Hi, not been here in a while.
I'm just poking around trying to find a chart that was here in past that shows what years the different cars had the change overs from small bolt pattern wheels to the big bolt pattern wheels.
Can someone please point me in the right direction?
Edit; I'm thinking it's '73, right?
Thx in Adv.
Re: small bolt pattern to big bolt pattern change over year [Re: moparz] #1411121
03/30/13 03:29 AM
03/30/13 03:29 AM
Missouri
MOBodyman Offline
MOBodyman  Offline
Missouri
Speaking of a-body cars here;
Beginning in 1973 all v-8 cars (a-bodies) had big bolt pattern (4 1/2") and disc brakes.
However discs were an option on '73-up /6 cars. If a /6 car had discs they were also big bolt pattern. However I've seen many '73-up /6 cars that still had drum brakes with small bolt pattern (4") wheels. I've never seen a '73-up /6 a-body with big bolt pattern and drum brakes.
Hope this helps,
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: small bolt pattern to big bolt pattern change over year [Re: MOBodyman] #1411122
03/30/13 03:47 AM
03/30/13 03:47 AM
Portland Oregon
69Dartman Offline
69Dartman  Offline
Portland Oregon
The doner car I bought cheap for the BB disk parts for my Dart was a 74 198 Dart 4 door that ran good and stopped for 150 becuase the car was just hideous looking so nobody was willing to buy it.
Like he said the low option no power/6 cars got SB drums till 75 I beleive and everything else got BB disks. I bought the doner after asking on the phone if it had disk brakes and still drove and stopped. I went and made sure and paid the guy his asking price and drove it home. That was quite a few years ago but was a smokin deal just for the parts and a good thing to keep in mind when looking for doner cars.
Life's a little bit better when you hit a Camaro.
Re: small bolt pattern to big bolt pattern change over year [Re: moparz] #1411123
03/30/13 04:01 AM
03/30/13 04:01 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
72 and back A bodies with front disc brakes were 5 on 4".
73 and up A bodies with front disc brakes were 5 on 4-1/2".
All A bodies with 4 wheel drum brakes were 5 on 4".
Re: small bolt pattern to big bolt pattern change over year [Re: nomore65BelvJim] #1411124
03/30/13 11:07 AM
03/30/13 11:07 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is the best explaination! My 75 Dart SE 4-door slant six has the big bolt discs and 8-1/4 rear.
JB Rhinehart, Realist
A-Body's RULE!
Re: small bolt pattern to big bolt pattern change over year [Re: Rhinodart] #1411125
03/30/13 12:18 PM
03/30/13 12:18 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Starting around Jan 1976, all A bodies were 4.5" and disc, 4" and drums were discontinued.
Re: small bolt pattern to big bolt pattern change over year [Re: B5 Bee] #1411126
03/30/13 01:09 PM
03/30/13 01:09 PM
OK so there were never any A body 4.5" front drums?
Re: small bolt pattern to big bolt pattern change over year [Re: RapidRobert] #1411127
03/30/13 01:33 PM
03/30/13 01:33 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
No 4.5" drums from the factory but it can be done with OEM parts.
The 73-up A bodies used an upper A arm with a larger ball joint (same size as B body) on both drums and discs. So if you want a 4.5" drum on your A body, use the 73-newer upper A arm and a spindle/brake set up from a 66-70 B body.
Re: small bolt pattern to big bolt pattern change over year [Re: B5 Bee] #1411128
03/30/13 01:37 PM
03/30/13 01:37 PM
I wanted to clarify what's what on that deal. Thank you!
Re: small bolt pattern to big bolt pattern change over year [Re: nomore65BelvJim] #1411129
03/30/13 05:41 PM
03/30/13 05:41 PM
Edmonton AB, CAN
moparz Offline OP
moparz  Offline OP
Edmonton AB, CAN
thanks all.
