Small block 4" crank bearings #1410982
03/29/13 08:06 PM
03/29/13 08:06 PM
ont,canada
mopartuner Offline OP
ont,canada
I need to buy bearings to start assembling my new build and I am having problems finding the right part numbers.I am using a MP hd cast crank that has been turned .020 on the mains and .010 on the rods.This is a full fillet crank(i think that is the correct term?)I want to use a main bearing with a full groove.The crank has 360 main size
410 pump gas solis flat tappet cam 10.95 so far
Re: Small block 4" crank bearings [Re: mopartuner] #1410983
03/29/13 08:16 PM
03/29/13 08:16 PM
BPE Offline
BPE  Offline
Re: Small block 4" crank bearings [Re: BPE] #1410984
03/29/13 08:23 PM
03/29/13 08:23 PM
ont,canada
ont,canada
You should be able to use these on the mains.
http://www.summitracing.com/parts/cle-ms1266p20/overview/make/plymouth
And these on the rods.
http://www.summitracing.com/parts/cle-cb481hn10/overview/make/plymouth
Hope this helps.
Rod
Thanks for the reply but one of those is the "P" seies and one is the "H" series should they not be the same?
Re: Small block 4" crank bearings [Re: mopartuner] #1410985
03/29/13 08:33 PM
03/29/13 08:33 PM
BPE Offline
BPE  Offline
From what you posted you have a cast crank, not that it would make any difference. I have customers that run race only applications with P series on the mains and H series on the rods with no issues what so ever. Just trying to help.
Rod
Re: Small block 4" crank bearings [Re: BPE] #1410986
03/29/13 08:41 PM
03/29/13 08:41 PM
ont,canada
ont,canada
Rod
I really appreciate the help I am just trying to understand bearing usage and fit.I have a stock crank here for another engine and it doesn't have a radius where it meets the weight like this stroker crank has.I want to make sure these bearings will fit
Re: Small block 4" crank bearings [Re: mopartuner] #1410987
03/29/13 09:49 PM
03/29/13 09:49 PM
BPE Offline
BPE  Offline
All of the BPE cranks that I sell have radius' on the mains and rods. Yes a P-bearings will fit on the mains and the HN-bearings will fit the rods.
Rod
Re: Small block 4" crank bearings [Re: BPE] #1410988
03/29/13 10:20 PM
03/29/13 10:20 PM
ont,canada
ont,canada
Rod
Thankyou.........will call you for my next crank.Cheers
Re: Small block 4" crank bearings [Re: mopartuner] #1410989
03/30/13 11:00 AM
03/30/13 11:00 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Can't you scrape a matching radius into the bearings with a knife? That's what I did on my stroker- nothing radical just broke the edge a little.
