why is my steering wheel not straight? #1410808
03/29/13 02:55 PM
03/29/13 02:55 PM
California
mickm Offline OP
mickm  Offline OP
California
i put a new steering box in. i turned it lock to lock, counted the turns, and then set it exactly in the middle. i then pointed the steering wheel straight ahead, and slid the coupler in place on the steering shaft. it only goes on one way, so i know that part is right.
i thought my wheels were pointed straight ahead, so connected the steering link.
the car drives perfectly straight down the road, but the steering wheel is 90 degrees to the right.
i though i just must not have had the wheels straight, so i got it pointed straight ahead, locked the steering column, raised the car up, disconnected the steering arm, turned the wheel to the straight ahead position, and connected it back up.
no change!
what's up?
Re: why is my steering wheel not straight? [Re: mickm] #1410809
03/29/13 03:47 PM
03/29/13 03:47 PM
(1) I'd turn the pitman arm till it's halfway thru its' travel then (2) adj toe with the 2 sleeves till I have even toe then ~1/16" in on each side then (3) install steering coupler with st wheel straight ahead & cut a new spline if needed. EDIT You've already got your toe corrected when it was aligned so on #2 just get the wheels straight ahead like you mentioned & install the pitman at that point (halfway thru the pitmans' travel) then #3, getting the steering wheel straight via the coupler
Re: why is my steering wheel not straight? [Re: mickm] #1410810
03/29/13 04:54 PM
03/29/13 04:54 PM
Minnesota
Mad Accountant Offline
Minnesota
An easier fix may be to get the wheels pointed straight ahead, and then pull the steering wheel and reset it on the column so it's straight. Beats pulling the linkages apart, cutting new splines, hooking it all back up and finding out its still not quite right.
Re: why is my steering wheel not straight? [Re: Mad Accountant] #1410811
03/29/13 05:02 PM
03/29/13 05:02 PM
California
mickm Offline OP
mickm  Offline OP
California
at first that sounded good, but if the steering box is not in the exact center position, then i'm driving down the road straight ahead with the steering box not centered.
seems to me that i need to make sure the box is in the exact (or close) middle position, lock to lock, and that is the point where i want the wheels perfectly straight ahead?
it sounds like i have the wheels straight ahead with the steering box not at it's center point, and so need to correct that.
am i off here?
Re: why is my steering wheel not straight? [Re: mickm] #1410812
03/29/13 05:19 PM
03/29/13 05:19 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
All boxes can be a little different. Use the tie rods to center the wheel. If the toe is correct, lengthen one while shortening the other the same amount.
Re: why is my steering wheel not straight? [Re: Jim_Lusk] #1410813
03/29/13 05:58 PM
03/29/13 05:58 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Put a piece of tape on the steering wheel at the 12:00 possition with the wheels straight. That will give you a reference point while you move the wheel lock to lock. Count the turns and make sure the box is centered. I though my pitman arm had a master spline so you couldn't get it in the wrong spot.
Re: why is my steering wheel not straight? [Re: mickm] #1410814
03/29/13 06:02 PM
03/29/13 06:02 PM
Minnesota
Minnesota
[at first that sounded good, but if the steering box is not in the exact center position, then i'm driving down the road straight ahead with the steering box not centered.
Sounds to me like you have the box centered already. Manual or power box?
Re: why is my steering wheel not straight? [Re: Mad Accountant] #1410815
03/29/13 07:23 PM
03/29/13 07:23 PM
California
mickm Offline OP
mickm  Offline OP
California
manual box. i don't think it is centered now. not with the wheels straight ahead. i'll have to do some playing around tonight...
Re: why is my steering wheel not straight? [Re: Jim_Lusk] #1410816
03/29/13 08:08 PM
03/29/13 08:08 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Re: why is my steering wheel not straight? [Re: 6PakBee] #1410817
03/29/13 08:22 PM
03/29/13 08:22 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Funny no one suggested a wheel alignment...bring it to my specialized alignment shop here in Virginia where we use a process called WinToe...the steering wheel is first centered then the passenger front tie rod is adjusted to specification and locked down followed by the drivers side. The steering wheel will then be centered and your toe adjusted to specification. I know, I know..your too far away,,,,
Re: why is my steering wheel not straight? [Re: dmoore] #1410818
03/29/13 08:33 PM
03/29/13 08:33 PM
IN
ahy Offline
ahy  Offline
IN
On most stock setups, there is a master spline on the steering wheel and pitman. They can only go together one way. Agree best bet is to adjust it out with the tie rods.
Another thing to check - did you by chance have the pot coupler apart? if it is re-assembled 180 degrees out from original it can throw the wheel off. Reason I know is I did it once.
Re: why is my steering wheel not straight? [Re: dmoore] #1410819
03/29/13 08:34 PM
03/29/13 08:34 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Do you have the pitman arm on the box in the right position? Most mopar boxes I have seen have 4 wide grooves on the spline coming out of the box and you can clock the pitman arm 4 different ways.
Re: why is my steering wheel not straight? [Re: Y3 70 BEE] #1410820
03/29/13 11:48 PM
03/29/13 11:48 PM
California
mickm Offline OP
mickm  Offline OP
California
ok, so here's the scoop.
i marked the pitman arm and the shaft on the steering box with the wheels straight ahead, which means the steering wheel was 90 degrees to the right. i then pulled the pitman arm, and brought the steering wheel to center. the two marks hardly moved. then i realized that with the 96 turns lock to lock that the standard steering box has, 1/2 a turn is not going to move things much, which is why when i did this the first time, all i did was put it back in the position it was originally in. so i reconnected the pitman arm, in the same position.
looking in the FSM, it mentioned adjusting the tie rods to align the steering wheel, and then it struck me, that was it.
so looked at the tie rod sleeves, and on the left side there were only a few threads exposed on the tie rod ends, while on the right side there were many. i remember when we put this together a long time ago remarking on that, but it drove, steered and aligned just fine.
anyway, the direction i needed to go brought the tie rod sleeves more in balance with how many threads were exposed on each side. took almost 4 turns to bring it in line, and now the steering wheel is straight and it still cruises down the road nice and straight.
i think the thing is the old box has enough slop that it needed things set this way to keep it going straight.
Re: why is my steering wheel not straight? [Re: mickm] #1410821
03/30/13 12:59 AM
03/30/13 12:59 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Personally,since you adjusted the tie rod end's,I'd have the toe checked.
Re: why is my steering wheel not straight? [Re: 62maxwgn] #1410822
03/30/13 01:12 AM
03/30/13 01:12 AM
with the wheels kept immobile & moving 1 sleeve in & the other out the same amount which would move the pitman/box & would center the steering wheel but I think that'd move the box away from exactly centered but evidently that ain't causing an issue (so far) & it sounds like it's all good if the tire wear stays acceptable (toe in). I also would suggest checking the toe in
Re: why is my steering wheel not straight? [Re: RapidRobert] #1410823
03/30/13 03:03 AM
03/30/13 03:03 AM
California
mickm Offline OP
mickm  Offline OP
California
i'll have the alignment checked...
