Polishins Exhaust ports
#1410800
03/29/13 02:52 PM
03/29/13 02:52 PM
Posts: 22,696 Bitopia
jcc
Bitopia
So its frowned on to polish intake ports for fuel suspension reasons, etc. Can/should exhaust ports be polished? Any downside? We are talking CNC ported Alum heads.
Re: Polishins Exhaust ports
[Re: jcc]
#1410801
03/29/13 03:02 PM
03/29/13 03:02 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
I know a very good HP machine shop in SO CA that polished the ports on a set of Dart BB Chevy CNC ported heads, they flowed the heads before and after, the customer didn't like the LOOKS(ridges) of the CNC finish, there was no measurable difference or gains in the ports by polishing the lines away If it is a street car and your concern is exhaust port carbon buildup go for it, if it is a drag race car don't waste your time I had a set of Eddy RPM that I had Jeff at Modern Cylinder Heads CNC port, I raced it a lot and drove it on the street some on Oregon pump gas, no noticable carbon build up on them the last time I had the heads off
[Re: jcc]
#1410804
03/30/13 11:56 AM
03/30/13 11:56 AM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I bought my cnc eddy heads for Jeff at MCH. I wanted to pay extra to polish the exhaust ports old shool style. He told me he would not do it, and to save my money. "The ridges keep the air in suspension and the exhaust port is already too large", and that is a quote.
Since that conversation, I don't bother with over polishing any exhuast ports that I work on. I use my dremel and a particular small stone to nicely cut a similar finish and pattern in the bowls and runner. I still polish valves.
Now on the other hand, I hear that some Nascar teams further rework cnc heads by hand. I guess it is all application.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: racealittle]
#1410805
03/30/13 12:16 PM
03/30/13 12:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I still polish the exhaust ports... the piston is pushing out the burnt gasses so I try to reduce any possible restriction and it helps the draft pulse on the over lap.... JMO
[Re: racealittle]
#1410806
03/31/13 11:46 AM
03/31/13 11:46 AM
Posts: 4,209 New York
polyspheric
New York
That pretty much takes him off the "ask" list.
Boffin Emeritus
[Re: racealittle]
#1410807
03/31/13 12:17 PM
03/31/13 12:17 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
what i usually tell people,, you want a surface that has enough texture to create the thinnest boundary layer possible,, if the surface finish is so coarse that it creates a larger boundary layer, you reduce the funcyional cross section of the port
polishing out minor ridges from a typical cnc'd head wont do anything for you,, polishing the chamber to reduce surface area,,, wont do anything for you,, on a cast chamber there is a great deal of surface area,, and polishing gains are very minimal..
guys make too big of a deal about this....
id guess if you had an 800 hp motor with cnc'd heads,,, if you polished the ports and chambers,, maybe it would hit 802hp
this is just a myth that people would "think" work,, like lightweight parts rev up faster going down track,,, they all do,, the gains are just soooo very minimal......
