Re: picking up a 2003 dodge durango r/t for a beater
[Re: buildanother]
#1410670
03/29/13 02:39 PM
03/29/13 02:39 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I had around a 2000, it's been a few years and can't remember... but loved it other than it had the typical messed up trans. Only other problem was the hatches like to rust out.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1410671
03/29/13 03:07 PM
03/29/13 03:07 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I had a '01. Many wiring issues. Steering column, ignition switch, turn signal switch, heater resistor harness. Recently the shifter cable broke. Power seat track is messed up. (A friend bought it) I'm having trouble keeping up on all the repairs. Hope you have better luck. Under 120, 000 miles.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: 79machocharger]
#1410672
03/29/13 04:43 PM
03/29/13 04:43 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Looking at a used durango r/t with 140000 miles on it. I'm only paying $1500.00 for it and it needs a new windsheild for sticker. Whats some things I should look for on it that are problem areas on these. I dont expect it to be pefect for the money I'm paying but dont want to waste my money on a complete piece of junk. I'm only going to be driving it back and forth from work which is only a couple of miles away and using it to haul my boat to camp at the begining of summer and end. I'll make sure to check the fluids in it and make sure they look some what decent. Any other input on what I should check on it would be helpfull. Thanks
Upper lower ball joint. Tie rod ends. Front and back Stabilizer link ends. Wheel bearings. If it has a posi the clips that hold the posi clutches break. Mostly wear and tear stuff.
