Page 4 of 4 1 2 3 4
Re: The official E-85 thread [Re: cudaman1969] #1410265
04/04/13 06:18 AM
04/04/13 06:18 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Thank you for the info. Charlotteville is the closest. Can you explain the percentages, smaller number more alcohol or less?
If you are asking about the percentages on the chart I listed it the deference between the low cost and high cost of E85 at the pump, I think. Selling price highs and lows.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The official E-85 thread [Re: pittsburghracer] #1410266
04/04/13 09:01 AM
04/04/13 09:01 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Maryland comes up with zero
http://e85prices.com/archive.php?state=maryland&year=2013&month=allmonths
There is a station in Annapolis that has E-85. Only station I know of.
Re: The official E-85 thread [Re: Dodgeguy101] #1410267
04/04/13 11:37 AM
04/04/13 11:37 AM
PA
ajcasini Offline
ajcasini  Offline
PA
So the number e85 is 85% ethanol 15%gas. E45 is 45% eth 55% gas. So you mix e85 with 89 octane unleaded to dilute the mixture from 85% to 45%. Gives you some benefits of ethanol without major carb mods.
Re: The official E-85 thread [Re: ajcasini] #1410268
04/04/13 11:39 AM
04/04/13 11:39 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
So the number e85 is 85% ethanol 15%gas. E45 is 45% eth 55% gas. So you mix e85 with 89 octane unleaded to dilute the mixture from 85% to 45%. Gives you some benefits of ethanol without major carb mods. [/quote
What is the end result octane of E45?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: The official E-85 thread [Re: tboomer] #1410269
04/04/13 01:01 PM
04/04/13 01:01 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
A few months back I was wondering about the actual octane of E85 (since all the usual web sites seemed to me to be quoting each other) so I went web searching and found this document:
http://ethanolrfa.3cdn.net/dd9e74ce1c454a97cc_rbm6bdgh3.pdf
It's full of good information about fuels, historical and current, and how and why various changes were made over the years. It also includes a chart for determining the alcohol content of a blend and it's a LOT more complicated than those cute little test bottles sold by the web sites that encourage E85 use. It also includes a statement of the octane of E85 that's sure to PO a lot of people who've accepted and quoted the number found on so many web sites. I found it interesting reading, you may not.
These questions have been popping up lately on E-85. I am also considering the changeover. So...Let's have some good input on this. Likes? Dislikes? Tips? Thanks,guys!!
Re: The official E-85 thread [Re: @#$%&*!] #1410270
04/04/13 09:54 PM
04/04/13 09:54 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Has anyone heard about E85 causing issues with certain kinds of oil? Brad Penn states to not use there oil with E85.
Brad Penn
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: The official E-85 thread [Re: 69dart] #1410271
04/04/13 10:37 PM
04/04/13 10:37 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I have run brad penn and mobil1 for years and had no issues.
Re: The official E-85 thread [Re: @#$%&*!] #1410272
04/04/13 10:52 PM
04/04/13 10:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know most of the stuff quote in the article I do
disagree with his octane rating.. there is only 1
way to test true octane and thats on a knock engine
and I am sure he doesnt have one... we wrote our own
data base for release(Chrysler Fuel Lab which I was
part of) and we had to base the octane on US release
data since they are one of the few places that has
a knock engine... my own results say that its higher
than he posted.. my engine would be knocking big time
if it was low 90s....
As to the oil question that would be the only one I
have heard of... Chrysler doesnt spec any one oil
to stay away from... unless Penn feels that it could
be diluted on short cold runs on a drag strip..
otherwise I have no clue
Re: The official E-85 thread [Re: MR_P_BODY] #1410273
04/05/13 01:42 PM
04/05/13 01:42 PM
MN
hemidup Offline
hemidup  Offline
MN
Quick question... Whats the difference in octane rating between winter blend E70 and summer blend E85?
Jerry Williams.
Re: The official E-85 thread [Re: MR_P_BODY] #1410274
04/05/13 02:35 PM
04/05/13 02:35 PM
Guitar Jones Offline
It says the calculations were confirmed by actual engine knock tests.
Octane: A minimum octane for E85 is not specified. FFV’s
can tolerate the lower octane of gasoline i.e. 87 (R+M)/2.
There is no requirement to post octane on an E85 dispenser.
If a retailer chooses to post octane, they should be aware that
the often cited 105 octane is incorrect. This number was
derived by using ethanol’s blending octane value in gasoline.
This is not the proper way to calculate the octane of E85.
Ethanol’s true octane value should be used to calculate E85’s
octane value. This results in an octane range of 94-96 (R+M)/
2. These calculations have been confirmed by actual octane
engine tests.
Page 4 of 4 1 2 3 4
