Page 3 of 4 1 2 3 4
Re: The official E-85 thread [Re: Quicktree] #1410245
03/29/13 05:03 PM
03/29/13 05:03 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
LOL ok car farts blueberrys
Re: The official E-85 thread [Re: Quicktree] #1410246
03/29/13 10:50 PM
03/29/13 10:50 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
come to find out the dig 6 is not recommended for alcohol/methanol and anything over 11:1 compression so that may be the problem.
Quictree, I have been running a Digital 6 Plus for 5-6 years. First with a 11:1 451 ci. then 451 12.7:1, and now 493 ci 13:1 no problems.
A couple years ago with 12.7:1 451 ci, had a similar hiccup when I would hit the throttle VERY fast while on 2 step. It was at the begining of the season when the air was cool And dry. This was with a converted 950 HP (4150) I put a 50 cc pump on the front and staged @ a warmer temp, cured the problem.
I have been using a 3 circuit 1050 Dom. which is probably richer. Havent had that problem.
Hope this helps, Don
Re: The official E-85 thread [Re: cudadon] #1410247
03/29/13 10:54 PM
03/29/13 10:54 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thats what MSD said mine does comong off the 2 step not going on. it is at full throttle
Re: The official E-85 thread [Re: Quicktree] #1410248
03/31/13 01:39 PM
03/31/13 01:39 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I misunderstood you.
Mine would do it when staged I see the top yellow come on whack the pedal to the floor.
I think the 50cc pump help cover up the gulp of air when I slammed the throttle open. If it didn't stumble there was no problem with the run. Don
Re: The official E-85 thread [Re: cudadon] #1410249
03/31/13 11:59 PM
03/31/13 11:59 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Thought I would chime in on the thread. I may be a bit late but wanted to put out some information for what was posted previously. First off thank you to Bob, cudadon and tboomer for the kind words.
I have been running e85 for the last 6 seasons. I have run it anywhere from 8-1 compression up to 13.5-1 compression. I have had great success in running more consistent, quicker ets, all the while running cooler.
First off some of the issues I have have been related to the fuel system. The biggest issue I have seen is with BG 2 or 4 port fuel pressure regulators. The stem that is in them will decay and break apart thus plugging the floats. I have run everything from the 14.99 quick fuel dead heads up to the billet 90 dead heads from quick fuel or aeromotive. They all have worked flawlessly. The second issue i have seen is with foam in the fuel cell. I have had some foam that is fine with the fuel others that have broken apart immediately. To keep it safe remove the foam from the cell. Also run a stanless filter element. The glue they use on the paper gas filters can flake off and make it through to the fuel bowls.
Also I Do Not run any additives in the fuel. I store in a steel drum and keep it sealed tight and out of the sun. This has served me well. I do believe the issue lies in the additives that are part of the pump gas that the fuel is mixed with and can vary by region. If you need something a little marvel mystery oil will do very well. The biggest thing with additives is to not overdo it.
To move on to the requirements:
Overall the fuel requires 30% more to keep the same mixture on gas. So with that said your fuel pump, lines, filter, regulator and carburetor must flow 30% more than is required on gas. so if your car produces 600HP your fuel system must be capable of feeding a 780HP combination. (600 x 1.3 = 780). Most of the fuel systems we run are overkill so that is normally not the issue. The issue lies in making the carb flow 30% more fuel. This cannot be accomplished with only bigger jets.
The carburetor modifications:
First we must make all passages larger to accommodate for more fuel. This is everything from the needle and seat to the booster passages.
The idle passages are large enough to start with which is a good thing. The main wells must be properly sized for e85. this is a size in between that of gas and methanol. I use a ream to drill the sizes properly. I do use different sizes for 4150 carbs and 1150-1250 dominators.
Next we must use the proper emulsion circuits. I have found the best is to go back to the roots where holley started it all with 2 holes ranging in size from .024-.028 depending on carb size and cam specs.
Then we must resize the IFR. Range from .042-.046
After this we must resize the cross channel since we are resizing the booster. The booster pins must be enlarged. Again depending on the carb size and other engine specs.
Also your bleeds will depend on some factors but normally range HSB .023 - .029 IAB .054-.068.
Needle and seat must be alcohol compatible and from .130-.140 in size.
You also must change the accel pump gaskets to alcohol compatible and resize squirters .036-.050 depending on combo. I have not had to run 50cc pumps on anything i have tuned thus far.
Now to jet sizes you can normally bet on a jet size increase of 6-8 sizes. However I have tuned some that are more efficient with the carb mods and end up with the jets the same as on gas. Some have been 10 sizes higher. It is all depending on the combo. Also one trick I use if you want to run screw in jet extensioins is to drill them out as well so there is no restriction.
If you guys have any other questions let me know on here or PM me or email. I can do conversions, build new or do a kit for you.
Thanks for reading.
Re: The official E-85 thread [Re: ajcasini] #1410250
04/01/13 10:33 AM
04/01/13 10:33 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
That post right there is everything that needs to be known about running E85. Great post
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: The official E-85 thread [Re: slippery440] #1410251
04/01/13 03:27 PM
04/01/13 03:27 PM
sweden
sshemi Offline
sshemi  Offline
sweden
This year im gonna run redline addetive since on last tear down i found some black goo on the intake side witch i thought came from a faulty pcv valve bt later found out it comes from the fuel. Look exatly like burnt oil on the intake valves.
Guess it depends on who is makeing the fuel.
Found it on some fuel injection site they said it clogges the injectors.
Almost all running e85 had a map tune for gas so they could run a couple of tanks of gas to clean it off.
Re: The official E-85 thread [Re: slippery440] #1410252
04/02/13 07:50 AM
04/02/13 07:50 AM
tboomer Offline OP
tboomer  Offline OP
[quote)That post right there is everything that needs to be known about running E85. Great post
Thanks,AJ!! Great reading!
Re: The official E-85 thread [Re: tboomer] #1410253
04/02/13 10:08 AM
04/02/13 10:08 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I know this is the E85 thread, but does anyone use other ethanol/gas mixture ratios like E30? I'm curious about it since it is available at the pump here and has an octane rating of 94 (Our super unleaded is 90 here).
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: The official E-85 thread [Re: BBR] #1410254
04/02/13 10:30 AM
04/02/13 10:30 AM
PA
ajcasini Offline
ajcasini  Offline
PA
As you said just about anyone who runs pump gas runs a small amount of ethanol. Normally 10-20% depending on who produces the fuel.
I have had some experiment with up to e45 mixed with e85 and 89 octane to achieve the 45% requirement. This can be run without much modification and usually just requires a jet size increase and a small air bleed change.
One thing I didnt note in my post above are some common questions that everyone asks about with e85.
Spark Plug heat range - Normally 1 step hotter than on gas or same as gas. I like the NGK 56712A-7 plugs for all setups I have done so far.
Timing - Normally same as on gas. I run mine through timing intervals of 1-2* at a time until performance levels off then step back to last setting before performance level off.
Thanks for reading.
Re: The official E-85 thread [Re: MR_P_BODY] #1410255
04/02/13 04:12 PM
04/02/13 04:12 PM
pennsylvania
poboyengineering Offline
pennsylvania
Can this be stored in a 55 gallon plastic drum?
It should be stored in steel drums if your keeping it
for any length of time... plastic drums will permeate
which will kill any fuel.... unless the plastic drum
has a permeation barrier(which you can see along the
opening.. a different color plastic molded to the
other plastic)
what about the fuel cell? does this mean the car has to have a steel tank or cell?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: The official E-85 thread [Re: poboyengineering] #1410256
04/02/13 04:16 PM
04/02/13 04:16 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well we are not going to store fuel in the fuel cell for a long time like over the winter.
Re: The official E-85 thread [Re: VernMotor] #1410257
04/03/13 04:00 PM
04/03/13 04:00 PM
pennsylvania
pennsylvania
ok, guess i missed that point.
Re: The official E-85 thread [Re: poboyengineering] #1410258
04/03/13 06:48 PM
04/03/13 06:48 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ok tell me where the E-85 stations are in Va and Maryland.
Re: The official E-85 thread [Re: cudaman1969] #1410259
04/03/13 07:06 PM
04/03/13 07:06 PM
Q
Quicktree Offline
Quicktree  Offline
Q
go to e85.com and find them
Re: The official E-85 thread [Re: Quicktree] #1410260
04/03/13 08:56 PM
04/03/13 08:56 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
go to e85.com and find them [/quote
Been there done that, it said one in Fred city but it was closed. I don't want to ride 50 miles and hope it's open. Looking for stations that someone has been to and still in business.
Re: The official E-85 thread [Re: cudaman1969] #1410261
04/03/13 09:31 PM
04/03/13 09:31 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
E85 Prices
Submit E85 Price
E85 Archives
E85 Vehicles
E85 Prices Forum
E85Prices Archive
1.Select State
2.Select City
3.Select Year
Select Month
Average Price Spread
8.4% Average E85 Price
$3.15 Average Gas Price
$3.44
22
E85 Price Gas Price Price Spread Date City Station State Reported by
$3.03 $3.65 17% 02/22 Chester East Coast, 13200 Kingston Ave Virginia radster71 (11)
$3.03 $3.59 16% 02/19 Chester East Coast, 13200 Kingston Ave Virginia radster71 (11)
$3.03 $3.55 15% 03/08 Chester East Coast, 13200 Kingston Ave Virginia radster71 (11)
$3.03 $3.45 12% 02/14 Chester East Coast, 13200 Kingston Ave Virginia radster71 (11)
$3.19 $3.59 11% 02/14 Newport News Airport BP, 12257 Jefferson Avenue Virginia radster71 (11)
$3.22 $3.57 10% 03/08 Viginia Beach Navy Exchange Gas Station, 1449 Tomcat Blvd Virginia KD4REL (3)
$3.24 $3.55 9% 02/26 Hayes Phillips Energy, 2586 George Washington Memorial Highway Virginia Phillips Energy, Inc. (4)
$3.22 $3.52 9% 03/12 Chester East Coast, 13200 Kingston Ave Virginia radster71 (11)
$3.15 $3.45 9% 03/19 Chester East Coast, 13200 Kingston Ave Virginia radster71 (11)
$3.29 $3.59 8% 03/14 Newport News Airport BP, 12257 Jefferson Avenue Virginia radster71 (11)
$3.24 $3.51 8% 03/14 Hayes Phillips Energy, 2586 George Washington Memorial Highway Virginia Phillips Energy, Inc. (4)
$3.22 $3.47 7% 03/23 Viginia Beach Navy Exchange Gas Station, 1449 Tomcat Blvd Virginia DocHarley (2)
$3.22 $3.46 7% 03/27 Viginia Beach Navy Exchange Gas Station, 1449 Tomcat Blvd Virginia DocHarley (2)
$3.22 $3.41 6% 02/14 Viginia Beach Navy Exchange Gas Station, 1449 Tomcat Blvd Virginia darobman05 (1)
$3.26 $3.48 6% 03/27 Hayes Phillips Energy, 2586 George Washington Memorial Highway Virginia Phillips Energy, Inc. (4)
$3.03 $3.20 5% 01/26 Chester East Coast, 13200 Kingston Ave Virginia roseyangel (279)
$3.03 $3.20 5% 01/26 Petersburg East Coast, 6460 Boydton Plank Virginia roseyangel (279)
$3.20 $3.38 5% 02/15 Hayes Phillips Energy, 2586 George Washington Memorial Highway Virginia Phillips Energy, Inc. (4)
$3.25 $3.39 4% 01/16 Hayes Phillips Energy, 2586 George Washington Memorial Highway Virginia roseyangel (279)
$2.99 $3.09 3% 01/26 Charlottesville Stop In Station, 1220 Seminole Trail Virginia roseyangel (279)
$3.05 $3.09 1% 01/07 Wytheville Sheetz, 1340 N 4th St Virginia roseyangel (279)
2006-2007-2008-2009 (E85Prices.com) Design by Igor Jovic
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The official E-85 thread [Re: pittsburghracer] #1410262
04/03/13 09:33 PM
04/03/13 09:33 PM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: The official E-85 thread [Re: pittsburghracer] #1410263
04/04/13 01:08 AM
04/04/13 01:08 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thank you for the info. Charlotteville is the closest. Can you explain the percentages, smaller number more alcohol or less?
Re: The official E-85 thread [Re: ajcasini] #1410264
04/04/13 01:18 AM
04/04/13 01:18 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Could you elaborate on this? Im confused.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Page 3 of 4 1 2 3 4
