Re: The official E-85 thread
[Re: sam64]
#1410209
03/28/13 11:30 AM
03/28/13 11:30 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
I'm lucky enough to be far enough south that the blend never changes here. I bought a e85 Quickfuel 1050 4500 at the beginning of last season. I switch it back and fourth between my small block Dart and big block Challenger. I have figured out the jetting for both and will just pull it off one car and rejet it and put it on the other car. I won the Footbrake Championship at one of the toughest tracks to win at on e85 last year. I race multiple classes every weekend and was going through four barrels of 110 a season. I don't use much more e85 than I did of 110. I love the stuff! I've had one motor apart that has run on it and everything looked great inside it. It can get a little stubborn to start in cold weather but once you get some heat in the motor it will start like normal from then on.
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Jacob Pitt]
#1410210
03/28/13 11:40 AM
03/28/13 11:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was filling 2 drums of e-85 towards the end of the racing season (still the e-85 blend) to use in the spring time if I was going out early... around here it would drop down to e-70 during the winter months... I had QF set up my dom and it was perfect on idle but I did jet up 2 jet sizes for the wot... its much more consistent than the 110 fuel I was burning... in 1.5 years it payed for itself just in fuel cost... not adding in the wins EDIT I test every time before I buy it... I buy from Meijer and would ask someone in line for the last little bit in the nozzle to fill my tester... most were curious to see what I was doing and would wait for the answer
[Re: MR_P_BODY]
#1410212
03/28/13 12:45 PM
03/28/13 12:45 PM
Posts: 982 western pennsylvania
b1dartsport
Mike,if you find the blend off,what do you do? Just not buy it at that time? Or do you have some way to fix it? Sorry for the dumb question but I have no experience with this and I have been thinking about making the switch.
[Re: tboomer]
#1410213
03/28/13 12:47 PM
03/28/13 12:47 PM
MR_P_BODY
Can this be stored in a 55 gallon plastic drum?
It should be stored in steel drums if your keeping it for any length of time... plastic drums will permeate which will kill any fuel.... unless the plastic drum has a permeation barrier(which you can see along the opening.. a different color plastic molded to the other plastic)
[Re: sam64]
#1410215
03/28/13 12:58 PM
03/28/13 12:58 PM
Posts: 25,931 United Socialist States of Ame...
tboomer
after jacking with a qf kit I ordered a carb from eric at horsepower innovations and it has worked very good for 2 years now.
Sam...What trouble did you have? I have a nice 1150 dominator that I want to convert..Don't have enough scrap metal to haul in to get a new one!! I think a Q/F dommy is around 1100.00?
[Re: tboomer]
#1410216
03/28/13 01:11 PM
03/28/13 01:11 PM
Posts: 833 MN
hemidup
MN
From our region I'd buy a E85 tester Ted. Cost's like $20, but you'll know the E rating. There is a difference between summer and winter blends up here.
Jerry Williams.
[Re: hemidup]
#1410218
03/28/13 01:26 PM
03/28/13 01:26 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
I also have a carb from Eric at Horsepower innovation. Some of the best customer service I've ever had, I promote his stuff any chance I can get. http://www.horsepowerinnovations.com/concrete/I love the stuff so far in my turbo car. Cheap race gas that will take a beating. That being said... I have had some issues with the fuel. I let my car sit for about 3 months after it came off the chassis dyno, while I was finishing up some other wiring/interior/roll bar stuff. When I went to start it up, the car ran terrible. I pulled the carb apart and it had really "goo'd up" inside. I had to send it back to Eric for him to completely go back through it. I'm not quite sure why it happened, because there are certainly lots of guys who don't do any maintanence with the fuel. I honestly believe them, but from seeing it with my own eyes, it can have issues. I was just more careful this year when I put the car away for the winter. I just ran 93 octane through it so I didn't have to worry about it.
[Re: dizuster]
#1410220
03/28/13 01:46 PM
03/28/13 01:46 PM
MR_P_BODY
I cant remember if you had the stock tank on it or a new one but if it was old the fuel that was used in it for years would have left residue and that would have lifted and got up front
[Re: tboomer]
#1410222
03/28/13 06:47 PM
03/28/13 06:47 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I like the stuff, but I've seen/learned a few things A) a vacuum pump helps get the water vapor out and oil looks good longer.
b)I need to take my carb apart more often and clean, have had a few rust/corrosion issues(pump springs, steel button on the pump dia.,white fuzz/goop) now I pull it apart every few months. A little lite oil on the block gasket to main body helps that area to stay nice.
C)It takes longer to build heat in the engine warm it up early in the lanes, and don't go to the line cold. Sure is nice when you are hot lapping in hot weather.
"Just a Bracket car dressed up like a streetcar"
[Re: sam64]
#1410223
03/28/13 08:23 PM
03/28/13 08:23 PM
Quicktree
had a really bad dead spot I coulndn't get rid of,and seemed lean no matter what I did.
what kind of ignition? i had the same problem coming off the 2 step.
[Re: Just-a-dart]
#1410224
03/28/13 08:30 PM
03/28/13 08:30 PM
MR_P_BODY
I found if the car will set longer than a week... drain the fuel and run some gas for a minute to get it in the engine... saves from alot of crap in the carb, mainly the water corrosion on anything thats not plated
