Re: The official E-85 thread
[Re: ajcasini]
#1410268
04/04/13 11:39 AM
04/04/13 11:39 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
So the number e85 is 85% ethanol 15%gas. E45 is 45% eth 55% gas. So you mix e85 with 89 octane unleaded to dilute the mixture from 85% to 45%. Gives you some benefits of ethanol without major carb mods. [/quote
What is the end result octane of E45?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: MR_P_BODY]
#1410274
04/05/13 02:35 PM
04/05/13 02:35 PM
Guitar Jones
I know most of the stuff quote in the article I do disagree with his octane rating.. there is only 1 way to test true octane and thats on a knock engine and I am sure he doesnt have one... we wrote our own data base for release(Chrysler Fuel Lab which I was part of) and we had to base the octane on US release data since they are one of the few places that has a knock engine... my own results say that its higher than he posted.. my engine would be knocking big time if it was low 90s.... As to the oil question that would be the only one I have heard of... Chrysler doesnt spec any one oil to stay away from... unless Penn feels that it could be diluted on short cold runs on a drag strip.. otherwise I have no clue
It says the calculations were confirmed by actual engine knock tests.
Octane: A minimum octane for E85 is not specified. FFV’s can tolerate the lower octane of gasoline i.e. 87 (R+M)/2. There is no requirement to post octane on an E85 dispenser. If a retailer chooses to post octane, they should be aware that the often cited 105 octane is incorrect. This number was derived by using ethanol’s blending octane value in gasoline. This is not the proper way to calculate the octane of E85. Ethanol’s true octane value should be used to calculate E85’s octane value. This results in an octane range of 94-96 (R+M)/ 2. These calculations have been confirmed by actual octane engine tests.
